Joint stiffness identification of six-revolute industrial serial robots, Robotics and Computer-Integrated Manufacturing, vol.27, issue.4, pp.881-888, 2011. ,
DOI : 10.1016/j.rcim.2011.02.003
URL : https://hal.archives-ouvertes.fr/hal-00632989
A Systematic Procedure for the Elastodynamic Modeling and Identification of Robot Manipulators, IEEE Transactions on Robotics, vol.26, issue.6, pp.1085-1093, 2010. ,
DOI : 10.1109/TRO.2010.2066910
URL : https://hal.archives-ouvertes.fr/hal-00755847
The effect of kinematic model complexity on manipulator accuracy, Proceedings, 1989 International Conference on Robotics and Automation, pp.593-598, 1989. ,
DOI : 10.1109/ROBOT.1989.100049
On the accuracy of a stewart platform -part i. the effect of manufacturing tolerances, IEEE Int. Conf. on Robotics and Automation (ICRA), pp.114-120, 1993. ,
Kinematic modeling and calibration of a Stewart platform, Advanced Robotics, vol.11, issue.5, pp.519-539, 1997. ,
DOI : 10.1163/156855397X00191
Optimized flexural hinge shapes for microsystems and high-precision applications, Mechanism and Machine Theory, pp.1826-1839, 2009. ,
DOI : 10.1016/j.mechmachtheory.2009.03.007
Design and experiment of a 3-DOF parallel micromechanism utilizing flexure hinges, IEEE Trans. on Robotics and Automation, vol.19, issue.4, pp.604-612, 2003. ,
Analysis and design of parallel mechanisms with flexure joints, IEEE Trans. on Robotics, vol.4, issue.6, pp.4097-4102, 2004. ,
Calibration of the 6 DOF highprecision flexure parallel robot " Sigma 6, Parallel Kinematic Machines in Research and Practice. Chemnitz: Neugebauer Reimund, pp.379-398, 2006. ,
Conceptional design and kinematics modeling of a wide-range flexure hinge-based parallel manipulator, IEEE Int. Conf. on Robotics and Automation (ICRA), pp.4031-4036, 2005. ,
Modeling and identification of non-geometric parameters in semi-flexible parallel robots, International Symposium on Robotics and Manufacturing, pp.115-120, 1996. ,
Kinematic calibration of the parallel Delta robot, Robotica, vol.16, issue.2, pp.207-218, 1998. ,
DOI : 10.1017/S0263574798000538
Interval method for calibration of parallel robots: Vision-based experiments, Mechanism and Machine Theory, pp.929-944, 2006. ,
DOI : 10.1016/j.mechmachtheory.2006.03.014
URL : https://hal.archives-ouvertes.fr/hal-00907729
Calibration of a hexapod machine tool using a redundant leg, International Journal of Machine Tools and Manufacture, vol.40, issue.4, pp.489-512, 2000. ,
DOI : 10.1016/S0890-6955(99)00081-4
A DBB-Based Kinematic Calibration Method for In-Parallel Actuated Mechanisms Using a Fourier Series, Journal of Mechanical Design, vol.126, issue.5, pp.856-865, 2004. ,
DOI : 10.1115/1.1767822
Method for kinematic calibration of stewart platforms, Journal of Robotic Systems, vol.110, issue.2, pp.391-405, 1993. ,
DOI : 10.1002/rob.4620100306
Experimental kinematic calibration of parallel manipulators using a relative position error measurement system, Robotics and Computer-Integrated Manufacturing, vol.26, issue.6, pp.799-804, 2010. ,
DOI : 10.1016/j.rcim.2010.05.007
Autonomous calibration of single-loop closed kinematic chains formed by manipulators with passive endpoint constraints, IEEE Transactions on Robotics and Automation, vol.7, issue.5, pp.597-606, 1991. ,
DOI : 10.1109/70.97871
Kinematic calibration using a plane constraint, Proceedings of International Conference on Robotics and Automation, pp.3191-3196, 1997. ,
DOI : 10.1109/ROBOT.1997.606774
Self calibration of Stewart-Gough parallel robots without extra sensors, IEEE Transactions on Robotics and Automation, vol.15, issue.6, pp.1116-1121, 1999. ,
DOI : 10.1109/70.817674
An implicit loop method for kinematic calibration and its application to closed-chain mechanisms, IEEE Transactions on Robotics and Automation, vol.11, issue.5, pp.710-724, 1995. ,
DOI : 10.1109/70.466613
Calibration of parallel robots using two inclinometers, Proceedings 1999 IEEE International Conference on Robotics and Automation (Cat. No.99CH36288C), pp.1758-1763, 1999. ,
DOI : 10.1109/ROBOT.1999.770363
Kinematic calibration of the Gough Platform, Robotica, vol.21, issue.6, pp.667-690, 2003. ,
DOI : 10.1017/S0263574703005083
URL : https://hal.archives-ouvertes.fr/hal-00907770
Parallel Robots, 2006. ,
DOI : 10.1007/978-94-010-9587-7
URL : https://hal.archives-ouvertes.fr/lirmm-00127856
Nouvelle architecture pour un manipulateur parallele a six degres de liberte, Mechanism and Machine Theory, vol.26, issue.1, pp.77-90, 1991. ,
DOI : 10.1016/0094-114X(91)90023-W
Flexure pivot for aerospace mechanisms, 10th European Space Mechanisms and Tribology Symposium, pp.285-288, 2003. ,
Elliptical-Arc-Fillet Flexure Hinges: Toward a Generalized Model for Commonly Used Flexure Hinges, Journal of Mechanical Design, vol.133, issue.8, p.81002, 2011. ,
DOI : 10.1115/1.4004441
Pose estimation from corresponding point data, IEEE Transactions on Systems, Man, and Cybernetics, vol.19, issue.6, pp.1426-1446, 1989. ,
DOI : 10.1109/21.44063
The constant-Jacobian method for kinematics of a three-DOF planar micro-motion stage, Journal of Robotic Systems, vol.37, issue.354, pp.63-72, 2002. ,
DOI : 10.1002/rob.1070
Mécanique des systèmes et des milieux déformables, 2004. ,
Study of the sources of inaccuracy of a 3 DOF flexure hinge-based parallel manipulator, IEEE International Conference on Robotics and Automation, 2004. Proceedings. ICRA '04. 2004, pp.4091-4096, 2004. ,
DOI : 10.1109/ROBOT.2004.1308911
Choosing Measurement Poses for Robot Calibration with the Local Convergence Method and Tabu Search, The International Journal of Robotics Research, vol.24, issue.6, pp.501-518, 2005. ,
DOI : 10.1177/0278364905053185
URL : https://hal.archives-ouvertes.fr/hal-00907749
The noise amplification index for optimal pose selection in robot calibration, Proceedings of IEEE International Conference on Robotics and Automation, pp.647-654, 1996. ,
DOI : 10.1109/ROBOT.1996.503848
Observability index selection for robot calibration, 2008 IEEE International Conference on Robotics and Automation, pp.831-836, 2008. ,
DOI : 10.1109/ROBOT.2008.4543308
Fundamentals of Manipulator Calibration, 1991. ,
