Using models to model-check recursive schemes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Sylvain Salvati
We propose a model-based approach to the model checking problem for recursive schemes. Since simply typed lambda calculus with the fixpoint operator, lambda-Y-calculus, is equivalent to schemes, we propose to use a model of lambda-Y to discriminate the terms that satisfy a given property. If a model is finite in every type, this gives a decision procedure. We provide a construction of such a model for every property expressed by automata with trivial acceptance conditions and divergence testing. We argue that having a model capable of recognizing terms satisfying a given property has other benefits than just providing decidability of the model-checking problem. We show a very simple construction transforming a scheme to a scheme reflecting a given property.
m.pdf (339.08 Ko) Télécharger le fichier
hal-00741077 , version 1 (11-10-2012)
hal-00741077 , version 2 (12-10-2012)
  • HAL Id : hal-00741077 , version 2
Sylvain Salvati, Igor Walukiewicz. Using models to model-check recursive schemes. TLCA 2013, 2013, Eindhoven, Netherlands. pp.189-204. ⟨hal-00741077v2⟩
199 Consultations
220 Téléchargements
