Improving Premise Structure in Evolving Takagi-Sugeno Neuro-Fuzzy Classifiers
We present in this paper a new method for the design of evolving neurofuzzy classifiers. The presented approach is based on a first-order Takagi-Sugeno neuro-fuzzy model.We propose a modification on the premise structure in this model and we provide the necessary learning formulas, with no problem-dependent parameters. We demonstrate by the experimental results the positive effect of this modification on the overall classification performance.
Apprentissage [cs.LG]
