Stable determination of conductivity by boundary measurements, Applicable Analysis, vol.1975, issue.1-3, pp.153-172, 1988. ,
DOI : 10.2307/1971291
Stable determination of corrosion by a single electrostatic boundary measurement, Inverse Problems, vol.19, issue.4, p.973, 2003. ,
DOI : 10.1088/0266-5611/19/4/312
Lipschitz stability for the inverse conductivity problem, Advances in Applied Mathematics, vol.35, issue.2, pp.207-241, 2005. ,
DOI : 10.1016/j.aam.2004.12.002
Identification of generalized impedance boundary conditions in inverse scattering problems, Inverse Problems and Imaging, vol.4, issue.1, pp.19-38, 2010. ,
DOI : 10.3934/ipi.2010.4.19
URL : https://hal.archives-ouvertes.fr/inria-00349258
Identification of Robin coefficients by the means of boundary measurements, Inverse Problems, vol.15, issue.6, pp.1425-1438, 1999. ,
DOI : 10.1088/0266-5611/15/6/303
Inverse acoustic and electromagnetic scattering theory, Applied Mathematical Sciences, vol.93, 1998. ,
DOI : 10.1007/978-1-4614-4942-3
On the detection of a moving obstacle in an ideal fluid by a boundary measurement, Inverse Problems, vol.24, issue.4, p.45001, 2008. ,
DOI : 10.1088/0266-5611/24/4/045001
Examples of exponential instability for inverse inclusion and scattering problems, Inverse Problems, vol.19, issue.3, p.685, 2003. ,
A Periodic Faddeev-Type Solution Operator, Journal of Differential Equations, vol.128, issue.1, pp.300-308, 1996. ,
DOI : 10.1006/jdeq.1996.0096
New Stability Estimates for the Inverse Acoustic Inhomogeneous Medium Problem and Applications, of Applied Mathematical Sciences, pp.670-685, 1996. ,
DOI : 10.1137/S0036141001383564
Stability of the Recovery of Surface Impedances in Inverse Scattering, Journal of Mathematical Analysis and Applications, vol.231, issue.1, pp.161-176, 1999. ,
DOI : 10.1006/jmaa.1998.6222
Problèmes aux limites non homogènes et applications, Travaux et Recherches Mathématiques, 1968. ,
Exponential instability in an inverse problem for the Schr??dinger equation, Inverse Problems, vol.17, issue.5, pp.1435-1444, 2001. ,
DOI : 10.1088/0266-5611/17/5/313
Lipschitz stability for the inverse conductivity problem, Adv. in Appl. Math. Adv. in Appl. Math, vol.35, issue.361, pp.207-24167, 2005. ,
Stable Determination of the Surface Impedance of an Obstacle by Far Field Measurements, SIAM Journal on Mathematical Analysis, vol.38, issue.2, pp.434-451, 2006. ,
DOI : 10.1137/050631513
Lipschitz stability for the inverse Robin problem, Inverse Problems, vol.23, issue.3, pp.1311-1326, 2007. ,
DOI : 10.1088/0266-5611/23/3/027
URL : https://hal.archives-ouvertes.fr/inria-00106334
Stability of the inverse problem in potential scattering at fixed energy, Annales de l???institut Fourier, vol.40, issue.4, pp.867-884, 1990. ,
DOI : 10.5802/aif.1239
Linearizing non-linear inverse problems and an application to inverse backscattering, Journal of Functional Analysis, vol.256, issue.9, pp.2842-2866, 2009. ,
DOI : 10.1016/j.jfa.2008.10.017
Electrical impedance tomography and Calder??n's problem, Inverse Problems, vol.25, issue.12, p.123011, 2009. ,
DOI : 10.1088/0266-5611/25/12/123011
