Object location using path separators, Proceedings of the twenty-fifth annual ACM symposium on Principles of distributed computing , PODC '06, pp.188-197, 2006. ,
DOI : 10.1145/1146381.1146411
URL : https://hal.archives-ouvertes.fr/hal-00400425
Routing in Networks with Low Doubling Dimension, 26th IEEE International Conference on Distributed Computing Systems (ICDCS'06), p.75, 2006. ,
DOI : 10.1109/ICDCS.2006.72
URL : https://hal.archives-ouvertes.fr/hal-00400501
Network synchronization with polylogarithmic overhead Emergence of scaling in random networks Ultimate generalizations of lexbfs and lex m, Proceedings of the 31st IEEE Symposium on Foundations of Computer Science (FOCS) Proceedings of the 31st International Workshop on Graph-Theoretic Concepts in Computer Science (WG), pp.514-522509, 1990. ,
A unified view of graph searching, SIAM Journal on Discrete Mathematics, vol.22, issue.4, pp.1259-1276, 2008. ,
Improved compact routing scheme for chordal graphs Compact routing schemes for generalised chordal graphs, Proceedings of the 16th International Conference on Distributed Computing (DISC), pp.252-264277, 2002. ,
DOI : 10.7155/jgaa.00109
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.87.5320
Estimating all pairs shortest paths in restricted graph families: a unified approach, Journal of Algorithms, vol.57, issue.1, pp.1-21, 2005. ,
Incidence matrices and interval graphs, Pacific Journal of Mathematics, vol.15, issue.3, pp.835-855, 1965. ,
DOI : 10.2140/pjm.1965.15.835
URL : http://projecteuclid.org/download/pdf_1/euclid.pjm/1102995572
Routing in Trees, Proceedings of the 28th International Colloquium on Automata, Languages and Programming (ICALP), pp.757-772, 2001. ,
DOI : 10.1007/3-540-48224-5_62
URL : https://hal.archives-ouvertes.fr/hal-00307398
Greedy routing in tree-decomposed graphs, Proceedings of the 13th Annual European Symposium on Algorithms (ESA), pp.791-802, 2005. ,
A survey on interval routing, Theoretical Computer Science, vol.245, issue.2, pp.217-253, 2000. ,
Space-Efficiency for Routing Schemes of Stretch Factor Three, Journal of Parallel and Distributed Computing, vol.61, issue.5, pp.679-687, 2001. ,
DOI : 10.1006/jpdc.2000.1705
Algorithmic Graph Theory and Perfect Graphs, 2004. ,
Memory requirements for routing in distributed networks (extended abstract), Proceedings of the 15th Annual ACM Symposium on Principles of Distributed Computing (PODC), pp.125-133, 1996. ,
The Compactness of Interval Routing, SIAM Journal on Discrete Mathematics, vol.12, issue.4, pp.459-473, 1999. ,
DOI : 10.1137/S0895480197328631
The Compactness of Interval Routing for Almost All Graphs, SIAM Journal on Computing, vol.31, issue.3, pp.706-721, 2001. ,
DOI : 10.1137/S0097539799351717
Alusim: simulating routing schemes on large-scale topologies, 2009. ,
DOI : 10.1109/pads.2010.5471662
URL : https://hal.inria.fr/inria-00440114/document
Interval Routing onk-Trees, Journal of Algorithms, vol.26, issue.2, pp.325-369, 1998. ,
DOI : 10.1006/jagm.1997.0880
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.48.7005
A trade-off between space and efficiency for routing tables, Journal of the ACM, vol.36, issue.3, pp.510-530, 1989. ,
DOI : 10.1145/65950.65953
Labelling and Implicit Routing in Networks, The Computer Journal, vol.28, issue.1, pp.5-8, 1985. ,
DOI : 10.1093/comjnl/28.1.5
Compact oracles for reachability and approximate distances in planar digraphs, Journal of the ACM, vol.51, issue.6, pp.993-1024, 2004. ,
DOI : 10.1145/1039488.1039493
Compact routing schemes, Proceedings of the thirteenth annual ACM symposium on Parallel algorithms and architectures , SPAA '01, pp.1-10, 2001. ,
DOI : 10.1145/378580.378581
