Wideband frequency domain detection using Teager-Kaiser energy operator - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper addresses wireless microphone sensing in the TV white space and efficient detection of narrowband FM modulation signals. To this end, a wideband frequency domain analysis is proposed. The required Fast Fourier Transform for this operation may be shared between sensing analysis and modulation functions. A particular decision metric is then studied for the analysis of wireless microphone signals based on the Teager-Kaiser energy operator. Simulation results show that 6 dB of detection gain could be achieved when using a frequency domain analysis compared to time domain methods. The Teager-Kaiser detection leads to further improvement of 1.5 dB. This performance could be reached at no extra cost in term of complexity.
TK_version_finale.pdf (256.44 Ko) Télécharger le fichier
hal-00742528 , version 1 (16-10-2012)
  • HAL Id : hal-00742528 , version 1
Matthieu Gautier, Vincent Berg, Dominique Noguet. Wideband frequency domain detection using Teager-Kaiser energy operator. IEEE 5th International Conference on Cognitive Radio Oriented Wireless Networks and Communications (Crowncom'12), Jun 2012, Stockholm, Sweden. ⟨hal-00742528⟩
291 Consultations
616 Téléchargements
