Stochastic geometry models in high-level vision, Journal of Applied Statistics, vol.55, issue.5-6, 1993. ,
DOI : 10.1098/rsta.1990.0127
Object Extraction Using a Stochastic Birth-and-Death Dynamics in Continuum, Journal of Mathematical Imaging and Vision, vol.21, issue.3, 2009. ,
DOI : 10.1007/s10851-008-0117-y
URL : https://hal.archives-ouvertes.fr/inria-00422411
Marked point processes for crowd counting, 2009 IEEE Conference on Computer Vision and Pattern Recognition, 2009. ,
DOI : 10.1109/CVPR.2009.5206621
Geometric feature extraction by a multi-marked point process, PAMI, vol.32, 2010. ,
URL : https://hal.archives-ouvertes.fr/inria-00503140
Depth Map Calculation for a Variable Number of Moving Objects using Markov Sequential Object Processes, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.30, issue.7, 2008. ,
DOI : 10.1109/TPAMI.2008.45
A marked point process for modeling lidar waveforms, 2010. ,
URL : https://hal.archives-ouvertes.fr/inria-00503149
Point processes for unsupervised line network extraction in remote sensing, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.27, issue.10, 2005. ,
DOI : 10.1109/TPAMI.2005.206
Marked point process for vasculartree extraction on angiogram, 2007. ,
A 3-D marked point process model for multi-view people detection, CVPR 2011, 2011. ,
DOI : 10.1109/CVPR.2011.5995699
Reversible jump Markov chain Monte Carlo computation and Bayesian model determination, Biometrika, vol.82, issue.4, 1995. ,
DOI : 10.1093/biomet/82.4.711
Monte Carlo sampling methods using Markov chains and their applications, Biometrika, vol.57, issue.1, 1970. ,
DOI : 10.1093/biomet/57.1.97
Range image segmentation by an effective jumpdiffusion method, PAMI, vol.26, 2004. ,
Jump???diffusion Markov processes on orthogonal groups for object pose estimation, Journal of Statistical Planning and Inference, vol.103, issue.1-2, 2002. ,
DOI : 10.1016/S0378-3758(01)00195-1
Image Segmentation by Data-Driven Markov Chain Monte Carlo, PAMI, vol.24, 2002. ,
Parallel chains, delayed rejection and reversible jump mcmc for object recognition, 2000. ,
On the parallelisation of MCMC-based image processing, 2010 IEEE International Symposium on Parallel & Distributed Processing, Workshops and Phd Forum (IPDPSW), 2010. ,
DOI : 10.1109/IPDPSW.2010.5470896
Parallel Gibbs sampling: From colored fields to thin junction trees, Journal of Machine Learning Research, 2011. ,
Towards the parallelization of Reversible Jump Markov Chain Monte Carlo algorithms for vision problems, Research report INRIA, vol.8016, 2012. ,
Higher Order Active Contours, International Journal of Computer Vision, vol.24, issue.12, p.69, 2006. ,
DOI : 10.1007/s11263-006-6851-y
URL : https://hal.archives-ouvertes.fr/inria-00070352
