J. A. Désidéri and M. Ii, A direct method for calculating a descent direction common to several criteria. INRIA research report, number 7922, 2012.
A. Zerbinati, J. A. Désidéri, and R. Duvigneau, Comparison between MGDA and PAES for multi objective optimization, INRIA research report, number 7667, 2011.
J. Knowles and D. Corne, Approximating the Nondominated Front Using the Pareto Archived Evolution Strategy, Evolutionary Computation, vol.8, issue.2, pp.149-172, 1999.
DOI : 10.1109/4235.797969
K. Deb, L. Thiele, M. Laumanns, and E. Zitzler, Scalable Test Problems for Evolutionary Multi-Objective Optimization, 2001.
C. Geuzaine and J. , Remacle : a three-dimensional finite element mesh generator with builtin pre-and post-processing facilities
