New interface
Journal articles
Nash Equilibrium Based Fairness
Abstract : There are several approaches of sharing resources among users. There is a noncooperative approach wherein each user strives to maximize its own utility. The most common optimality notion is then the Nash equilibrium. Nash equilibria are generally Pareto inefficient. On the other hand, we consider a Nash equilibrium to be fair as it is defined in a context of fair competition without coalitions (such as cartels and syndicates). We show a general framework of systems wherein there exists a Pareto optimal allocation that is Pareto superior to an inefficient Nash equilibrium.We consider this Pareto optimum to be 'Nash equilibrium based fair.'We further define a 'Nash proportionately fair' Pareto optimum. We then provide conditions for the existence of a Pareto-optimal allocation that is, truly or most closely, proportional to a Nash equilibrium. As examples that fit in the above framework, we consider noncooperative flow-control problems in communication networks, for which we show the conditions on the existence of Nash-proportionately fair Pareto optimal allocations.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/hal-00743123
Contributor : Corinne Touati Connect in order to contact the contributor
Submitted on : Thursday, October 18, 2012 - 10:58:46 AM
Last modification on : Tuesday, August 2, 2022 - 4:24:41 AM
Links full text
Identifiers
Citation
Hisao Kameda, Eitan Altman, Corinne Touati, Arnaud Legrand. Nash Equilibrium Based Fairness. Mathematical Methods of Operations Research, 2012, 76 (1), ⟨10.1007/s00186-012-0389-2⟩. ⟨hal-00743123⟩
Share
Metrics
Record views
134
