New interface
Journal articles
Application of the linear sampling method to identify cracks with impedance boundary conditions
Abstract : We use the linear sampling method (LSM) to identify a crack with impedance boundary conditions from far-field measurements at a fixed frequency. This article extends the work of Cakoni-Colton [F. Cakoni and D. Colton, The linear sampling method for cracks, Inverse Probl. 19 (2003), pp. 279-295] where LSM has been used to reconstruct a crack with impedance boundary conditions on one side of the crack and a Dirichlet boundary condition on the other one. In addition, we present two methods to also reconstruct the impedance parameters whence the geometry is known. The first one is based on the interpretation of the indicator function produced by the LSM, while the second one is a natural approach based on the integral representation of the far-field in terms of densities on the crack geometry. The performance of the different reconstruction methods is illustrated through numerical examples in a 2D setting of the scattering problem.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/hal-00743816
Contributor : Houssem Haddar Connect in order to contact the contributor
Submitted on : Saturday, October 20, 2012 - 9:20:41 PM
Last modification on : Wednesday, August 24, 2022 - 9:40:06 AM
Identifiers
Collections
Citation
Fahmi Ben Hassen, Yosra Boukari, Houssem Haddar. Application of the linear sampling method to identify cracks with impedance boundary conditions. Inverse Problems in Science and Engineering, 2012, pp.1-25. ⟨10.1080/17415977.2012.686997⟩. ⟨hal-00743816⟩
Share
Metrics
Record views
239
