New interface
Journal articles
Computing estimates of material properties from transmission eigenvalues
Giovanni Giorgi 1, 2 Houssem Haddar 1
1 DeFI - Shape reconstruction and identification
CMAP - Centre de Mathématiques Appliquées - Ecole Polytechnique, Inria Saclay - Ile de France
Abstract : This work is motivated by inverse scattering problems, those problems where one is interested in reconstructing the shape and the material properties of an inclusion from electromagnetic farfield measurements. More precisely, we are interested in complementing the so-called sampling methods by providing an estimate of the material properties of the sought inclusion. We use for this purpose a measure of the first transmission eigenvalue. Our method is then based on computing the desired estimate by reformulating the so-called interior transmission eigenvalue problem as an eigenvalue problem for the material coefficients. We will restrict ourselves to the two-dimensional setting of the problem and treat the cases of both transverse electric and transverse magnetic polarizations. We present a number of numerical experiments that validate our methodology for homogeneous and inhomogeneous inclusions and backgrounds. We also treat the case of a background with absorption and the case of scatterers with multiple connected components of different refractive indices.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/hal-00743910
Contributor : Houssem Haddar Connect in order to contact the contributor
Submitted on : Sunday, October 21, 2012 - 10:58:54 PM
Last modification on : Friday, November 25, 2022 - 6:50:05 PM
Links full text
Identifiers
Collections
Citation
Giovanni Giorgi, Houssem Haddar. Computing estimates of material properties from transmission eigenvalues. Inverse Problems, 2012, 28 (5), pp.055009, 23. ⟨10.1088/0266-5611/28/5/055009⟩. ⟨hal-00743910⟩
Share
Metrics
Record views
230
