New interface
Journal articles
Identification of small inclusions from multistatic data using the reciprocity gap concept
Abstract : We consider the problem of identifying small inclusions (or point sources) from multistatic Cauchy data at given surface measurements associated with harmonic waves at a fixed frequency. We employ the reciprocity gap sampling method to recover the location of the inclusions and identify their equivalent dielectric properties. As opposed to the case of extended obstacles, no approximation argument is needed in the theoretical justification of the method. These aspects are numerically validated through multiple numerical experiments associated with small inclusions.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/hal-00743911
Contributor : Houssem Haddar Connect in order to contact the contributor
Submitted on : Sunday, October 21, 2012 - 11:15:50 PM
Last modification on : Wednesday, August 24, 2022 - 9:40:06 AM
Links full text
Identifiers
Collections
Citation
Houssem Haddar, Ridha Mdimagh. Identification of small inclusions from multistatic data using the reciprocity gap concept. Inverse Problems, 2012, 28 (4), pp.045011, 19. ⟨10.1088/0266-5611/28/4/045011⟩. ⟨hal-00743911⟩
Share
Metrics
Record views
132
