New interface
Journal articles
Genetic optimization of a vehicle fuzzy decision system for intersections
Abstract : This paper presents a case study in which an autonomous vehicle must cooperate with a supposedly manually driven one to carry out a cross-roads manœuvre without risk. The main difference with other intersectionsystems is that the manual vehicle is driven without paying attention to the controlled one, so a cooperative coordination between vehicles is not possible. In this case is the autonomous vehicle the responsible of adapting its speed to the state of the manually driven, for finalizing the manœuvre both in a safe and efficient way. For this purpose, a three layer hierarchical fuzzy rule-based system (FRBS) is developed with the aim of dealing with such a situation: the first layer is in charge of detecting the kind of manœuvre that will be necessary; the second, in the case that an intersection is going to be crossed, is in charge of determining the suitable speed to do so without risk; and the third acts on the vehicle's real speed. The first two layers are implemented by means of fuzzydecisionsystems, with the second being optimized by agenetic algorithm (GA). The GA evaluates candidates in random simulated scenarios taking into account different factors to calculate the fitness. These factors are: implementing a free collision policy, avoiding unnecessary stops, and terminating the manœuvre as rapidly as possible.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/hal-00744249
Contributor : Joshué Pérez Rastelli Connect in order to contact the contributor
Submitted on : Monday, October 22, 2012 - 3:59:45 PM
Last modification on : Tuesday, November 29, 2022 - 12:12:15 PM
Identifiers
Collections
Citation
Enrique Onieva, Vicente Milanés, Jorge Villagra, Joshué Pérez Rastelli, Jorge Godoy. Genetic optimization of a vehicle fuzzy decision system for intersections. Expert Systems with Applications, 2012, 39 (18), pp.13148-13157. ⟨10.1016/j.eswa.2012.05.087⟩. ⟨hal-00744249⟩
Share
Metrics
Record views
128
