Inria IMEDIA2's Participation at ImageCLEF 2012 Plant Identification Task - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper describes the participation of Inria IMEDIA2 Team, within the Pl@ntNet project4, at the ImageCLEF2012 plant identi cation task. The runs used very distinct approaches, sometimes relying on similar extracted features. For Scan and Scan-like categories, the rst two runs combine distinct local and contour approaches in two ways (late and early fusion), while the third run explores the learning capacity of a multi-class SVM technique on a contour based descriptor. For Photo- graph our runs used local features positioned towards the center of the image to reduce the impact of background features. In the second run, an automatic segmentation with a rejection criterion was attempted. In the third run, points were associated with interesting zones. In general, even if they were distinct, the methods used performed very well.
Inria-IMEDIA2-runs-ImageCLEF2012.pdf (1.69 Mo) Télécharger le fichier
hal-00744901 , version 1 (24-10-2012)
  • HAL Id : hal-00744901 , version 1
Vera Bakić, Itheri Yahiaoui, Sofiène Mouine, Saloua Litayem Ouertani, Wajih Ouertani, et al.. Inria IMEDIA2's Participation at ImageCLEF 2012 Plant Identification Task. CLEF (Online Working Notes/Labs/Workshop) 2012, Sep 2012, Rome, Italy. ⟨hal-00744901⟩
611 Consultations
162 Téléchargements
