An XML-Based Lightweight C++ Fact Extractor, Proceedings of the 11th IEEE International Workshop on Program Comprehension, pp.134-143, 2003. ,
Conservation and replication with cvs-vintage : A dataset of cvs repositories of java software ,
Analyzing Exception Usage in Large Java Applications In Exception Handling in Object Oriented Systems : Towards Emerging Application Areas and New Programming Paradigms, pp.10-19, 2003. ,
Analyzing Exception Flow in Java Programs, Proceedings of the 7th European software engineering conference held jointly with the 7th ACM SIGSOFT international symposium on Foundations of software engineering, pp.322-337, 1999. ,
A Static Study of Java Exceptions Using JESP, Proceedings of the Ninth Annual International Conference on Compiler Construction, pp.67-81, 2000. ,
DOI : 10.1007/3-540-46423-9_5
Toward Exception-Handling Best Practices and Patterns, IEEE Software, vol.23, issue.5, pp.11-13, 2006. ,
DOI : 10.1109/MS.2006.144
