Abstract : Dynamic Partial Reconfiguration (DPR) has been introduced in recent years as a method to increase the flexibility of FPGA designs. However, using DPR for building com- plex systems remains a daunting task. Recently, approaches based on Model-Driven Engi- neering (MDE) and UML MARTE standard have emerged which aim to simplify the design of complex SoCs, and in some cases, DPR systems. Nevertheless, many of these approaches lacked a standard intermediate representation to pass from high-levels of descriptions to ex- ecutable models. However, with the recent standardization of the IP-XACT specification, there is an increasing interest to use it in MDE methodologies to ease system integration and to enable design flow automation. In this paper we propose an MARTE/MDE approach which exploits the capabilities of IP-XACT to model and automatically generate DPR SoC designs. We present the MARTE modeling concepts and how these models are mapped to IP-XACT objects; the emphasis is given to the generation of IP cores that can be used in the Xilinx EDK (Embedded Design Kit) environment, since we aim to develop a complete flow around their Dynamic Partial Reconfiguration design flow. Finally, we present a case study integrating the presented concepts, showing the benefits in design efforts compared with a purely VHDL approach and using solely EDK. Experimental results show a reduction of the design efforts required to obtain the netlist required for the DPR design flow from hours required in VHDL and Xilinx EDK, to less the one hour and minutes for IP integration.
