Mining association rules between sets of items in large databases, Proc. SIGMOD, pp.207-216, 1993. ,
Discovering local structure in gene expression data : the order-preserving submatrix problem, Proc. RECOMB, pp.49-57, 2002. ,
Mining a new faulttolerant pattern type as an alternative to formal concept discovery, Proc. ICCS, pp.144-157, 2006. ,
Identification of functional modules based on transcriptional regulation structure, BMC Proc, vol.2, p.4, 2008. ,
Approximate frequent itemset mining in the presence of random noise. Soft Computing for Knowledge Discovery and Data Mining, pp.363-389, 2008. ,
Biclustering of expression data, Proc. Int, pp.93-103, 2000. ,
On implementing the push-relabel method for the maximum flow problem, Algorithmica, vol.19, issue.4, pp.390-410, 1997. ,
SGD : Saccharomyces genome database, Nucleic Acids Research, vol.26, issue.1, pp.73-79, 1998. ,
A scalable framework for discovering coherent co-clusters in noisy data, Proc. ICML, p.31, 2009. ,
Genomic expression programs in the response of yeast cells to environmental changes, Mol. Biol. Cell, issue.12, pp.11-4241, 2000. ,
Using the bagging approach for biclustering of gene expression data, Neurocomputing, issue.10, pp.74-1595, 2011. ,
KEGG : Kyoto encyclopedia of genes and genomes, Nucleic Acids Res, vol.28, issue.1, pp.27-30, 2000. ,
A probalistic functionnal network of yeast genes, Science, issue.5701, pp.306-1555, 2004. ,
Maximal quasi-bicliques with balanced noise tolerance, Proc. SDM, pp.72-83, 2008. ,
Mining approximate frequent itemsets in the presence of noise : Algorithm and analysis, Proc. SDM, pp.405-416, 2006. ,
Extraction de motifs ensemblistes dans des contextes bruités, CAP 2011, pp.311-326, 2011. ,
Itemset mining in noisy contexts : A hybrid approach, Proc. ICTAI 2011, pp.33-40, 2011. ,
Biclustering of gene expression data by correlation-based scatter search, BioData Min, vol.4, issue.3, 2011. ,
Towards efficient mining of proportional fault-tolerant frequent itemsets, Proc. KDD, pp.697-706, 2009. ,
A systematic comparison and evaluation of biclustering methods for gene expression data, Bioinformatics, vol.22, issue.9, pp.1122-1129, 2006. ,
Dense itemsets, Proc. KDD, pp.683-688, 2004. ,
Ambiguous frequent itemset mining and polynomial delay enumeration, Proc. PAKDD, pp.357-368, 2008. ,
