New interface
Conference papers
Legacy Software Restructuring: Analyzing a Concrete Case
Nicolas Anquetil 1, * Jannik Laval 1
* Corresponding author
1 RMOD - Analyses and Languages Constructs for Object-Oriented Application Evolution
LIFL - Laboratoire d'Informatique Fondamentale de Lille, Inria Lille - Nord Europe
Abstract : Software re-modularization is an old preoccupation of reverse engineering research. The advantages of a well structured or modularized system are well known. Yet after so much time and efforts, the field seems unable to come up with solutions that make a clear difference in practice. Recently, some researchers started to question whether some basic assumptions of the field were not overrated. The main one consists in evaluating the high-cohesion/low-coupling dogma with metrics of unknown relevance. In this paper, we study a real structuring case (on the Eclipse platform) to try to better understand if (some) existing metrics would have helped the software engineers in the task. Results show that the cohesion and coupling metrics used in the experiment did not behave as expected and would probably not have helped the maintainers reach there goal. We also measured another possible restructuring which is to decrease the number of cyclic dependencies between modules. Again, the results did not meet expectations.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-00745773
Contributor : Lse Lse Connect in order to contact the contributor
Submitted on : Friday, October 26, 2012 - 1:25:12 PM
Last modification on : Saturday, June 25, 2022 - 7:44:51 PM
Long-term archiving on: : Saturday, December 17, 2016 - 5:53:48 AM
Identifiers
  • HAL Id : hal-00745773, version 1
  • ARXIV : 1210.7138
Citation
Nicolas Anquetil, Jannik Laval. Legacy Software Restructuring: Analyzing a Concrete Case. Proceedings of the 15th European Conference on Software Maintenance and Reengineering (CSMR'11), IEEE, Mar 2011, Oldenburg, Germany. pp.279--286. ⟨hal-00745773⟩
Share
Metrics
Record views
104
Files downloads
190
