A database and evaluation methodology for optical flow, Int. Conf. on Comp. Vis., ICCV 2007, 2007. ,
Variational Adaptive Correlation Method for Flow Estimation, IEEE Transactions on Image Processing, vol.21, issue.6, 2011. ,
DOI : 10.1109/TIP.2011.2181524
A three-frame algorithm for estimating two-component image motion, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.14, issue.9, pp.886-895, 1992. ,
DOI : 10.1109/34.161348
The variational bayesian em algorithm for incomplete data: with application to scoring graphical model structures, p.7453, 2003. ,
The Robust Estimation of Multiple Motions: Parametric and Piecewise-Smooth Flow Fields, Computer Vision and Image Understanding, vol.63, issue.1, pp.75-104, 1996. ,
DOI : 10.1006/cviu.1996.0006
Report 1 on production and diffusion of fluid mechanics images and data. Fluid project deliverable 1.2, 2005. ,
Dense estimation of fluid flows, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.24, issue.3, pp.365-380, 2002. ,
DOI : 10.1109/34.990137
URL : https://hal.archives-ouvertes.fr/hal-00329724
Wavelet-Based Fluid Motion Estimation, Scale Space Methods and Variational Methods (SSVM) in Computer Vision, 2011. ,
DOI : 10.1007/978-3-642-24785-9_62
Constrained restoration and the recovery of discontinuities, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.14, issue.3, pp.367-383, 1992. ,
DOI : 10.1109/34.120331
Robust Optic-Flow Estimation with Bayesian Inference of Model and Hyper-parameters, Image Processing IEEE Transactions on, issue.991, 2011. ,
DOI : 10.1007/978-3-642-24785-9_65
Bayesian selection of scaling laws for motion modeling in images, 2009 IEEE 12th International Conference on Computer Vision, 2009. ,
DOI : 10.1109/ICCV.2009.5459353
URL : https://hal.archives-ouvertes.fr/hal-00473262
Power laws and inverse motion modeling: application to turbulence measurements from satellite images, TellusA, vol.64, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00670364
Layered Estimation of Atmospheric Mesoscale Dynamics From Satellite Imagery, IEEE Transactions on Geoscience and Remote Sensing, vol.45, issue.12, pp.454087-4104, 2007. ,
DOI : 10.1109/TGRS.2007.906156
URL : https://hal.archives-ouvertes.fr/hal-00596167
Variational fluid flow measurements from image sequences: synopsis and perspectives, Experiments in Fluids, vol.28, issue.4, pp.369-393, 2010. ,
DOI : 10.1007/s00348-009-0778-3
URL : https://hal.archives-ouvertes.fr/hal-00456162
Determining optical flow, Artificial Intelligence, vol.17, issue.1-3, pp.185-203, 1981. ,
DOI : 10.1016/0004-3702(81)90024-2
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.185.1651
Convex half-quadratic criteria and interacting auxiliary variables for image restoration, IEEE Transactions on Image Processing, vol.10, issue.7, pp.1001-1009, 2001. ,
DOI : 10.1109/83.931094
Bayesian Methods: General Background, 1986. ,
DOI : 10.1017/CBO9780511569678.003
URL : http://bayes.wustl.edu/etj/articles/general.background.ps.gz
Divergence-free Wavelets and High Order Regularization, p.646104, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00646104
The Local Structure of Turbulence in Incompressible Viscous Fluid for Very Large Reynolds Numbers, Proceedings of the Royal Society A: Mathematical, Physical and Engineering Sciences, vol.434, issue.1890, pp.301-306, 1941. ,
DOI : 10.1098/rspa.1991.0075
Inertial Ranges in Two-Dimensional Turbulence, Physics of Fluids, vol.10, issue.7, pp.1417-1423, 1967. ,
DOI : 10.1063/1.1762301
Bayesian Model Selection for Optical Flow Estimation, DAGM-Symposium, pp.142-151, 2007. ,
DOI : 10.1007/978-3-540-74936-3_15
Effects of initial conditions in decaying turbulence generated by passive grids, Journal of Fluid Mechanics, vol.193, issue.1, pp.395-420, 2007. ,
DOI : 10.1017/S0022112092002325
Horizontal velocity structure functions in the upper troposphere and lower stratosphere: 2. Theoretical considerations, Journal of Geophysical Research: Atmospheres, vol.164, issue.D10, pp.233-241, 2001. ,
DOI : 10.1029/2000JD900815
Fluid flow and optical flow, Journal of Fluid Mechanics, vol.51, p.253, 2008. ,
DOI : 10.1023/A:1013614317973
An iterative image registration technique with an application to stereovision, Int. Joint Conf. on Artificial Intel. (IJCAI), pp.674-679, 1981. ,
Bayesian Interpolation, Neural Computation, vol.49, issue.3, pp.415-447, 1992. ,
DOI : 10.1093/comjnl/11.2.185
Direct Simulations of Helical Hall???MHD Turbulence and Dynamo Action, The Astrophysical Journal, vol.619, issue.2, p.1019, 2005. ,
DOI : 10.1086/426534
Bayesian and regularization methods for hyperparameter estimation in image restoration, IEEE Transactions on Image Processing, vol.8, issue.2, pp.231-246, 1999. ,
DOI : 10.1109/83.743857
Variational Assimilation of Fluid Motion from Image Sequence, SIAM Journal on Imaging Sciences, vol.1, issue.4, pp.343-363, 2008. ,
DOI : 10.1137/080713896
URL : https://hal.archives-ouvertes.fr/hal-00596149
The Bayesian Choice: From Decision-Theoretic Foundations to Computational Implementation ,
DOI : 10.1007/978-1-4757-4314-2
Optical Stokes flow estimation: an imaging-based control approach, Experiments in Fluids, vol.15, issue.3, pp.61-78, 2007. ,
DOI : 10.1007/s00348-006-0220-z
Variational estimation of experimental fluid flows with physics-based spatio-temporal regularization, Measurement Science and Technology, vol.18, issue.3, pp.755-763, 2007. ,
DOI : 10.1088/0957-0233/18/3/027
The Eigenvalues of Mega-dimensional Matrices, Maximum Entropy and Bayesian Methods, pp.455-466, 1989. ,
DOI : 10.1007/978-94-015-7860-8_48
Discrete Orthogonal Decomposition and Variational Fluid Flow Estimation, Journal of Mathematical Imaging and Vision, vol.34, issue.2, pp.67-80, 2007. ,
DOI : 10.1007/s10851-007-0014-9
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.529.4121
