Voice source localization for automatic camera pointing system in videoconferencing, 1997 IEEE International Conference on Acoustics, Speech, and Signal Processing, 1997. ,
DOI : 10.1109/ICASSP.1997.599595
Position-Location Solutions by Taylor-Series Estimation, IEEE Transactions on Aerospace and Electronic Systems, vol.12, issue.2, pp.187-194, 1976. ,
DOI : 10.1109/TAES.1976.308294
Closed-form least-squares source location estimation from range-difference measurements, IEEE Transactions on Acoustics, Speech, and Signal Processing, vol.35, issue.12, pp.1661-1669, 1987. ,
DOI : 10.1109/TASSP.1987.1165089
Lecture Notes - Source Localization from Range-Difference Measurements, IEEE Signal Processing Magazine, vol.23, issue.6, pp.63-69, 2006. ,
DOI : 10.1109/SP-M.2006.248717
The generalized correlation method for estimation of time delay, IEEE Transactions on Acoustics, Speech, and Signal Processing, vol.24, issue.4, pp.320-327, 1976. ,
DOI : 10.1109/TASSP.1976.1162830
Sparseness-Based 2CH BSS using the EM Algorithm in Reverberant Environment, 2007 IEEE Workshop on Applications of Signal Processing to Audio and Acoustics, pp.147-150, 2007. ,
DOI : 10.1109/ASPAA.2007.4393015
Grouping Separated Frequency Components by Estimating Propagation Model Parameters in Frequency-Domain Blind Source Separation, IEEE Transactions on Audio, Speech and Language Processing, vol.15, issue.5, pp.1592-1604, 2007. ,
DOI : 10.1109/TASL.2007.899218
An EM algorithm for localizing multiple sound sources in reverberant environments, Proc. Neural Information Processing Systems (NIPS), pp.953-960, 2006. ,
Robust Localization in Reverberant Rooms, Microphone Arrays: Signal Processing Techniques and Applications, 2001. ,
DOI : 10.1007/978-3-662-04619-7_8
Multiple emitter location and signal parameter estimation, IEEE Transactions on Antennas and Propagation, vol.34, issue.3, pp.276-280, 1986. ,
DOI : 10.1109/TAP.1986.1143830
Real-time tracking of multiple sound sources by integration of in-room and robot-embedded microphone arrays, Proc. IEEE/RSJ International Conference on Intelligent Robots and Systems, pp.852-859, 2006. ,
Crystal-MUSIC: Accurate Localization of Multiple Sources in Diffuse Noise Environments Using Crystal-Shaped Microphone Arrays, Proc. of LVA, pp.81-88, 2010. ,
DOI : 10.1007/978-3-642-15995-4_11
URL : https://hal.archives-ouvertes.fr/inria-00541858
A subspace rotation approach to signal parameter estimation, Proc. IEEE, pp.1044-1046, 1986. ,
DOI : 10.1109/PROC.1986.13583
Spatio-temporal spectral analysis by eigenstructure methods, IEEE Transactions on Acoustics, Speech, and Signal Processing, vol.32, issue.4, pp.817-827, 1984. ,
DOI : 10.1109/TASSP.1984.1164400
Measurement of Correlation Coefficients in Reverberant Sound Fields, The Journal of the Acoustical Society of America, vol.27, issue.6, pp.1072-1077, 1955. ,
DOI : 10.1121/1.1908122
A microphone array with adaptive post-filtering for noise reduction in reverberant rooms, ICASSP-88., International Conference on Acoustics, Speech, and Signal Processing, pp.2578-2581, 1988. ,
DOI : 10.1109/ICASSP.1988.197172
Microphone array post-filter based on noise field coherence, IEEE Trans. Speech Audio Process, vol.11, issue.6, pp.709-716, 2003. ,
Diffuse Noise Suppression Using Crystal-Shaped Microphone Arrays, IEEE Transactions on Audio, Speech, and Language Processing, vol.19, issue.7, pp.2101-2110, 2011. ,
DOI : 10.1109/TASL.2011.2112645
Isotropic Noise Suppression in the Power Spectrum Domain by Symmetric Microphone Arrays, 2007 IEEE Workshop on Applications of Signal Processing to Audio and Acoustics, pp.54-57, 2007. ,
DOI : 10.1109/ASPAA.2007.4393005
Designing the Wiener post-filter for diffuse noise suppression using imaginary parts of inter-channel cross-spectra, 2010 IEEE International Conference on Acoustics, Speech and Signal Processing, pp.2818-2821, 2010. ,
DOI : 10.1109/ICASSP.2010.5496202
URL : https://hal.archives-ouvertes.fr/inria-00544104
Spatial coherence functions for differential microphones in isotropic noise fields, Microphone Arrays: Signal Processing Techniques and Applications, pp.61-85, 2001. ,
Weighted low-rank approximations, Proc. International Conference on Machine Learning (ICML, pp.720-727, 2003. ,
An accelerated proximal gradient algorithm for nuclear norm regularized linear least squares problems, Pacific Journal of Optimization, vol.6, issue.3, pp.615-640, 2010. ,
Exact matrix completion via convex optimization, The Journal of the Society for the Foundations of Computational Mathematics, vol.9, issue.6, pp.717-772, 2009. ,
An accelerated gradient method for trace norm minimization, Proceedings of the 26th Annual International Conference on Machine Learning, ICML '09, pp.457-464, 2009. ,
DOI : 10.1145/1553374.1553434
The approximation of one matrix by another of lower rank, Psychometrika, vol.1, issue.3, pp.211-218, 1936. ,
DOI : 10.1007/BF02288367
A Tutorial on MM Algorithms, The American Statistician, vol.58, issue.1, pp.30-37, 2004. ,
DOI : 10.1198/0003130042836
A Fast Iterative Shrinkage-Thresholding Algorithm for Linear Inverse Problems, SIAM Journal on Imaging Sciences, vol.2, issue.1, pp.381-389, 2009. ,
DOI : 10.1137/080716542
Fixed point and Bregman iterative methods for matrix rank minimization, Mathematical Programming, pp.321-353, 2011. ,
DOI : 10.1007/s10107-009-0306-5
URL : http://arxiv.org/abs/0905.1643
Image method for efficiently simulating small???room acoustics, The Journal of the Acoustical Society of America, vol.65, issue.4, pp.943-950, 1979. ,
DOI : 10.1121/1.382599
ATR Japanese speech database as a tool of speech recognition and synthesis, Speech Communication, vol.9, issue.4, pp.357-363, 1990. ,
DOI : 10.1016/0167-6393(90)90011-W
Multi-source TDOA estimation in reverberant audio using angular spectra and clustering, Inria RESEARCH CENTRE RENNES ? BRETAGNE ATLANTIQUE Campus universitaire de Beaulieu 35042 Rennes Cedex Publisher Inria Domaine de Voluceau -Rocquencourt BP 105 -78153 Le Chesnay Cedex inria.fr ISSN, pp.249-6399, 1950. ,
DOI : 10.1016/j.sigpro.2011.09.032
URL : https://hal.archives-ouvertes.fr/inria-00576297
