Catapult-c synthesis ,
Code generation in the polyhedral model is easier than you think, Proceedings. 13th International Conference on Parallel Architecture and Compilation Techniques, 2004. PACT 2004., pp.7-16, 2004. ,
DOI : 10.1109/PACT.2004.1342537
URL : https://hal.archives-ouvertes.fr/hal-00017260
PLuTo: A practical and fully automatic polyhedral program optimization system, Proceedings of the ACM SIGPLAN Conference on Programming Language Design and Implementation, 2008. ,
Iterative optimization in the polyhedral model: Part II, multidimensional time, ACM SIGPLAN Conference on Programming Language Design and Implementation (PLDI'08), pp.90-100, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-01257273
Software Pipelining of Nested Loops, Proceedings of the 10th International Conference on Compiler Construction, ser. CC '01, pp.165-181, 2001. ,
DOI : 10.1007/3-540-45306-7_12
Single-dimension software pipelining for multidimensional loops, ACM Transactions on Architecture and Code Optimization, vol.4, issue.1, 2007. ,
DOI : 10.1145/1216544.1216550
Combined instruction and loop parallelism in array synthesis for FPGAs, Proceedings of the 14th international symposium on Systems synthesis , ISSS '01, pp.165-170, 2001. ,
DOI : 10.1145/500001.500039
Partitioning processor arrays under resource constraints, The Journal of VLSI Signal Processing, vol.17, issue.1, pp.5-20, 1997. ,
DOI : 10.1023/A:1007935215591
The Polyhedral Model Is More Widely Applicable Than You Think, Compiler Construction, pp.283-303, 2010. ,
DOI : 10.1007/978-3-642-11970-5_16
URL : https://hal.archives-ouvertes.fr/inria-00551087
Fuzzy array dataflow analysis, Proceedings of the fifth ACM SIGPLAN symposium on Principles and practice of parallel programming, pp.92-101, 1995. ,
Dataflow analysis of array and scalar references, International Journal of Parallel Programming, vol.24, issue.4, pp.23-53, 1991. ,
DOI : 10.1145/360827.360844
Generation of efficient nested loops from polyhedra, International Journal of Parallel Programming, vol.28, issue.5, pp.469-4981007554627716, 2000. ,
DOI : 10.1023/A:1007554627716
Code generation for multiple mappings, Proceedings Frontiers '95. The Fifth Symposium on the Frontiers of Massively Parallel Computation, pp.332-341, 1995. ,
DOI : 10.1109/FMPC.1995.380437
URL : http://www.cs.umd.edu/Library/TRs/CS-TR-3317.1/CS-TR-3317.1.ps.Z
Scanning polyhedra without Do-loops, Proceedings. 1998 International Conference on Parallel Architectures and Compilation Techniques (Cat. No.98EX192), p.4, 1998. ,
DOI : 10.1109/PACT.1998.727127
URL : https://hal.archives-ouvertes.fr/inria-00564990
Hardware Synthesis for Multi- Dimensional Time, " in ASAP, IEEE Computer Society, pp.40-50, 2003. ,
Classifying interprocess communication in process network representation of nested-loop programs, ACM Transactions on Embedded Computing Systems, vol.6, issue.2, 2007. ,
DOI : 10.1145/1234675.1234680
Counting Integer Points in Parametric Polytopes Using Barvinok's Rational Functions, Algorithmica, vol.48, issue.1, pp.37-66, 2007. ,
DOI : 10.1007/s00453-006-1231-0
URL : http://www.cs.kuleuven.be/~dtai/publications/files/41970.pdf
Parametric integer programming, RAIRO - Operations Research, vol.22, issue.3, pp.243-268, 1988. ,
DOI : 10.1051/ro/1988220302431
Integer Set Library: Manual, 2010. ,
DOI : 10.1007/978-3-642-15582-6_49
A LIBRARY FOR DOING POLYHEDRAL OPERATIONS, Parallel Algorithms and Applications, vol.15, issue.3-4, 1993. ,
DOI : 10.1007/BF02574699
URL : https://hal.archives-ouvertes.fr/inria-00074515
isl: An Integer Set Library for the Polyhedral Model, ICMS, ser, pp.299-302, 2010. ,
Some efficient solutions to the affine scheduling problem. I. One-dimensional time, International Journal of Parallel Programming, vol.40, issue.6, pp.313-347, 1992. ,
Handbook of Signal Processing Systems, Polyhedral process networks, 2004. ,
Increasing Pipelined IP Core Utilization in Process Networks Using Exploration, " in FPL, ser. Lecture Notes in Computer Science, pp.690-699, 2004. ,
Software pipelining, PLDI, pp.318-328, 1988. ,
DOI : 10.1145/989393.989420
Time optimal software pipelining of loops with control flows, International Journal of Parallel Programming, vol.31, issue.5, pp.339-3911027387028481, 2003. ,
DOI : 10.1023/A:1027387028481
CALiBeR: a software pipelining algorithm for clustered embedded VLIW processors, IEEE/ACM International Conference on Computer Aided Design. ICCAD 2001. IEEE/ACM Digest of Technical Papers (Cat. No.01CH37281), pp.112-118, 2001. ,
DOI : 10.1109/ICCAD.2001.968606
Software Pipelining in Nested Loops with Prolog-Epilog Merging, " in HiPEAC, ser. Lecture Notes in Computer Science, pp.80-94, 2009. ,
Loop coalescing and scheduling for barrier MIMD architectures, IEEE Transactions on Parallel and Distributed Systems, vol.4, issue.9, pp.1060-1064, 1993. ,
DOI : 10.1109/71.243531
ADJUSTING A PROGRAM TRANSFORMATION FOR LEGALITY, Parallel Processing Letters, vol.22, issue.01n02, pp.3-17, 2005. ,
DOI : 10.1142/S0129626497000401
Automatic Correction of Loop Transformations, 16th International Conference on Parallel Architecture and Compilation Techniques (PACT 2007), pp.292-30417, 2007. ,
DOI : 10.1109/PACT.2007.4336220
URL : https://hal.archives-ouvertes.fr/hal-01257283
