Journal articles
Does a parthenogenesis-inducing Wolbachia induce vestigial cytoplasmic incompatibility?
Ken Kraaijeveld 1 Barbara M Reumer 1 Laurence Mouton 2, 3 Natacha Kremer 3, 2 Fabrice Vavre 2, 3 Jacques J.M. van Alphen 4
2 BAMBOO - An algorithmic view on genomes, cells, and environments
Inria Grenoble - Rhône-Alpes, LBBE - Laboratoire de Biométrie et Biologie Evolutive - UMR 5558
3 Génétique et évolution des interactions hôtes-parasites
GINSENG - Département génétique, interactions et évolution des génomes [LBBE]
4 Paysages, Changements Climatique, Biodiversité
IBED - Institute for Biodiversity and Ecosystem Dynamics
Abstract : Wolbachia is a maternally inherited bacterium that manipulates the reproduction of its host. Recent studies have shown that male-killing strains can induce cytoplasmic incompatibility (CI) when introgressed into a resistant host. Phylogenetic studies suggest that transitions between CI and other Wolbachia phenotypes have also occurred frequently, raising the possibility that latent CI may be widespread among Wolbachia. Here, we investigate whether a parthenogenesis-inducing Wolbachia strain can also induce CI. Parthenogenetic females of the parasitoid wasp Asobara japonica regularly produce a small number of males that may be either infected or not. Uninfected males were further obtained through removal of the Wolbachia using antibiotics and from a naturally uninfected strain. Uninfected females that had mated with infected males produced a slightly, but significantly more male-biased sex ratio than uninfected females that had mated with uninfected males. This effect was strongest in females that mated with males that had a relatively high Wolbachia titer. Quantitative PCR indicated that infected males did not show higher ratios of nuclear versus mitochondrial DNA content. Wolbachia therefore does not cause diploidization of cells in infected males. While these results are consistent with CI, other alternatives such as production of abnormal sperm by infected males cannot be completely ruled out. Overall, the effect was very small (9%), suggesting that if CI is involved it may have degenerated through the accumulation of mutations.
Complete list of metadata
https://hal.inria.fr/hal-00746858
Contributor : Marie-France Sagot Connect in order to contact the contributor
Submitted on : Monday, October 29, 2012 - 6:42:07 PM
Last modification on : Saturday, September 24, 2022 - 2:36:04 PM
Links full text
Identifiers
Collections
Citation
Ken Kraaijeveld, Barbara M Reumer, Laurence Mouton, Natacha Kremer, Fabrice Vavre, et al.. Does a parthenogenesis-inducing Wolbachia induce vestigial cytoplasmic incompatibility?. The Science of Nature Naturwissenschaften, Springer Verlag, 2011, 98 (3), pp.175-80. ⟨10.1007/s00114-010-0756-x⟩. ⟨hal-00746858⟩
Share
Metrics
Record views
101
