Bacterial syntenies: an exact approach with gene quorum.
BACKGROUND: The automatic identification of syntenies across multiple species is a key step in comparative genomics that helps biologists shed light both on evolutionary and functional problems. RESULTS: In this paper, we present a versatile tool to extract all syntenies from multiple bacterial species based on a clear-cut and very flexible definition of the synteny blocks that allows for gene quorum, partial gene correspondence, gaps, and a partial or total conservation of the gene order. CONCLUSIONS: We apply this tool to two different kinds of studies. The first one is a search for functional gene associations. In this context, we compare our tool to a widely used heuristic--I-ADHORE--and show that at least up to ten genomes, the problem remains tractable with our exact definition and algorithm. The second application is linked to evolutionary studies: we verify in a multiple alignment setting that pairs of orthologs in synteny are more conserved than pairs outside, thus extending a previous pairwise study. We then show that this observation is in fact a function of the size of the synteny: the larger the block of synteny is, the more conserved the genes are.
Origin : Publisher files allowed on an open archive
