Multicore simulation of powertrains using weakly synchronized model partitioning - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The need of quick innovation in the automotive domain made simulation necessary at early stages of the development cycle. Vehicles and powertrains are complex systems where di erent domains are involved. Representative phenomenological models of powertrains have been developed and have been used in the design phase under domain dedicated tools. However, their use for controls validation using Model-In-the-Loop (MIL) and Hardware-In-the-Loop (HIL) was prevented due to performance limitation of widely used single-solver/single-core simulation approaches. This paper proposes a simulation approach for complex systems simulation, taking into account the fact that the computational power improvement in today processors is mainly driven by the augmentation of the number of cores per processor, rather than in cores frequency increase. It first focuses into numerical solvers characteristics, especially the time-step and order management, to identify their influence on the accuracy and the simulation speed. Then, a parallel simulation method is proposed in order to exploit more e ciently the parallelism provided by multi-core architectures, as well as involved complex systems nature (di erent dynamics and time scales), while avoiding disrupting simulation results. Finally, this method is validated on phenomenological engine test cases, and its e ectiveness is illustrated.
Automatique
ECOSM-12.pdf (249.08 Ko) Télécharger le fichier
hal-00746968 , version 1 (30-10-2012)
  • HAL Id : hal-00746968 , version 1
Abir Ben Khaled, Mohamed El Mongi Ben Gaïd, Daniel Simon, Gregory Font. Multicore simulation of powertrains using weakly synchronized model partitioning. E-COSM 2012 - IFAC Workshop on Engine and Powertrain Control Simulation and Modeling, Oct 2012, Rueil-Malmaison, France. ⟨hal-00746968⟩
495 Consultations
2915 Téléchargements
