Analytic vs. systemic approaches ,
Newton Methods for Nonlinear Problems, 2004. ,
DOI : 10.1007/978-3-642-23899-4
Time-decomposed parallel time-integrators: theory and feasibility studies for fluid, structure, and fluid-structure applications, International Journal for Numerical Methods in Engineering, vol.36, issue.9, pp.1397-1434, 2003. ,
DOI : 10.1002/nme.860
Methods for real-time simulation of cyberphysical systems: application to automotive domain, IWCMC'11, pp.1105-1110, 2011. ,
Principles of Object-Oriented Modeling and Simulation with Modelica, 2003. ,
DOI : 10.1109/9780470545669
Analyse de méthodes de résolutionparalì eles d'EDO/EDA raides, 2009. ,
Basic concepts of the systems ap- proach. Principia Cybernetica Web, 1998. ,
Algorithms and software for ordinary differential equations and differential- algebraic equations, Part II: Higher-order methods and software packages, Computers in Physics, vol.9, issue.2, pp.148-155, 1995. ,
DOI : 10.1063/1.168540
A space-time multigrid method for parabolic pdes, 1993. ,
Numerical simulation of power circuits using transmission-line modelling. IEE proceedings. Part A. Physical science, Measurements and instrumentation, Management and education, Reviews, issue.6, pp.137379-384, 1990. ,
Survey of the stability of linear finite difference equations, Communications on Pure and Applied Mathematics, vol.5, issue.2, pp.267-293, 1956. ,
DOI : 10.1002/cpa.3160090206
The Waveform Relaxation Method for Time-Domain Analysis of Large Scale Integrated Circuits, IEEE Transactions on Computer-Aided Design of Integrated Circuits and Systems, vol.1, issue.3, pp.131-145, 1982. ,
DOI : 10.1109/TCAD.1982.1270004
R??solution d'EDP par un sch??ma en temps ??parar??el ??, Comptes Rendus de l'Académie des Sciences -Series I -Mathematics, pp.661-668, 2001. ,
DOI : 10.1016/S0764-4442(00)01793-6
On the Use of System Simulation to Explore the Potential of Innovative Combustion Systems: Methodology and Application to Highly Downsized SI Engines Running with Ethanol-Gasoline Blends, SAE Technical Paper Series, pp.2011-2015, 2011. ,
DOI : 10.4271/2011-01-0408
On the Reduction of a 3D CFD Combustion Model to Build a Physical 0D Model for Simulating Heat Release, Knock and Pollutants in SI Engines, Oil & Gas Science and Technology - Revue de l'IFP, vol.64, issue.3, pp.223-242, 2009. ,
DOI : 10.2516/ogst/2008055
Parallel iteration of high-order Runge-Kutta methods with stepsize control, Journal of Computational and Applied Mathematics, vol.29, issue.1, pp.111-127, 1990. ,
DOI : 10.1016/0377-0427(90)90200-J
Brennverlauf und Kreisprozess von Verbrennungsmotoren, 1970. ,
