New interface
Journal articles
Path similarity evaluation using Bloom filters
Abstract : The performance of several Internet applications often relies on the measurability of path similarity between different participants. In particular, the performance of content distribution networks mainly relies on the awareness of content sources topology information. It is commonly admitted nowadays that, in order to ensure either path redundancy or efficient content replication, topological similarities between sources is evaluated by exchanging raw traceroute data, and by a hop by hop comparison of the IP topology observed from the sources to the several hundred or thousands of destinations. In this paper, based on real data we collected, we advocate that path similarity comparisons between different Internet entities can be much simplified using lossy coding techniques, such as Bloom filters, to exchange compressed topology information. The technique we introduce to evaluate path similarity enforces both scalability and data confidentiality while maintaining a high level of accuracy. In addition, we demonstrate that our technique is scalable as it requires a small amount of active probing and is not targets dependent.
Document type :
Journal articles
Complete list of metadata
Cited literature [16 references]  Display  Hide  Download
https://hal.inria.fr/hal-00748208
Contributor : Mohamed Ali Kaafar Connect in order to contact the contributor
Submitted on : Tuesday, January 29, 2013 - 3:19:12 PM
Last modification on : Thursday, November 10, 2022 - 4:22:14 AM
Long-term archiving on: : Tuesday, April 30, 2013 - 2:25:08 AM
File
paper.pdf
Identifiers
Citation
B. Donnet, B. Gueye, Mohamed Ali Kaafar. Path similarity evaluation using Bloom filters. Computer Networks, 2011, ⟨10.1016/j.comnet.2011.11.003⟩. ⟨hal-00748208⟩
Share
Metrics
Record views
94
Files downloads
483
