New interface
Conference papers
Geolocalization of proxied services and its application to fast-flux hidden servers
Claude Castelluccia 1 Mohamed Ali Kaafar 1, * P. Manils D. Perito
* Corresponding author
1 PLANETE - Protocols and applications for the Internet
Inria Grenoble - Rhône-Alpes, CRISAM - Inria Sophia Antipolis - Méditerranée
Abstract : Fast-flux is a redirection technique used by cyber-criminals to hide the actual location of malicious servers. Its purpose is to evade identification and prevent or, at least delay, the shutdown of these illegal servers by law enforcement. This paper proposes a framework to geolocalize fast-flux servers, that is, to determine the physical location of the fast-flux networks roots (mothership servers) based on network measurements. We performed an extensive set of measurements on PlanetLab in order to validate and evaluate the performance of our method in a controlled environment. These experimentations showed that, with our framework, fast-flux servers can be localized with similar mean distance errors than non-hidden servers, i.e. approximately 100 km. In the light of these very promising results, we also applied our scheme to several active fast-flux servers and estimated their geographic locations, providing then statistics on the locations of "in the wild" fast-flux services.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-00748235
Contributor : Mohamed Ali Kaafar Connect in order to contact the contributor
Submitted on : Monday, November 5, 2012 - 11:03:46 AM
Last modification on : Friday, February 4, 2022 - 3:14:40 AM
Links full text
Identifiers
Collections
Citation
Claude Castelluccia, Mohamed Ali Kaafar, P. Manils, D. Perito. Geolocalization of proxied services and its application to fast-flux hidden servers. Proceedings of the 9th ACM SIGCOMM conference on Internet measurement conference (IMC), Nov 2009, Chicago, United States. pp.184--189, ⟨10.1145/1644893.1644915⟩. ⟨hal-00748235⟩
Share
Metrics
Record views
77
