C. Parisot, M. Antonini, M. Barlaud, S. Tramini, C. Latry et al., Optimization of the joint coding/decoding structure, International Conference on Image Processing (ICIP), 2001.
S. B. Lo, B. Krasner, and S. K. Mun, Noise impact on error-free image compression, IEEE Transactions on Medical Imaging, vol.9, issue.2, pp.202-206, 1990.
R. Dobrushin and B. Tsybakov, Information transmission with additional noise, IRE Transactions on Information Theory, vol.8, issue.5, pp.293-304, 1962.
Y. Ephraim and R. M. Gray, A unified approach for encoding clean and noisy sources by means of waveform and autoregressive model vector quantization, IEEE Transactions on Information Theory, vol.34, issue.4, pp.826-834, 1988.
J. Wolf and J. Ziv, Transmission of noisy information to a noisy receiver with minimum distortion, IEEE Transactions on Information Theory, vol.16, issue.4, pp.406-411, 1970.
T. R. Fischer, J. D. Gibson, and B. Koo, Estimation and noisy source coding, IEEE Transactions on Acoustics, Speech and Signal Processing, vol.38, issue.1, pp.23-34, 1990.
DOI : 10.1109/29.45615
O. K. Shaykh and R. M. Mersereau, Lossy compression of noisy images, IEEE Transactions on Image Processing, vol.7, issue.12, pp.1641-1652, 1998.
. Fig, Visual comparison of reconstruction results. From left to right: Reference image, observed image, image reconstructed using the separated optimization of the on-ground distortion, image reconstructed using the joint optimization of the on-ground distortion model, image reconstructed using the separated optimization of the on-board distortion and image reconstructed using the joint optimization of the on-board distortion model. The coding rate is 2
M. Antonini, M. Barlaud, P. Mathieu, and I. Daubechies, Image coding using wavelet transform, IEEE Transactions on Image Processing, vol.1, issue.2, pp.205-220, 1992.
URL : https://hal.archives-ouvertes.fr/hal-01322224
J. H. Kasner, M. W. Marcellin, and B. R. Hunt, Universal trellis coded quantization, IEEE Transactions on Image Processing, vol.8, issue.12, pp.1677-1687, 1999.
DOI : 10.1109/isit.1995.550420
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.49.4607
V. Chappelier and C. Guillemot, Oriented wavelet transform for image compression and denoising, IEEE Transactions on Image Processing, vol.15, issue.10, pp.2892-2903, 2006.
URL : https://hal.archives-ouvertes.fr/inria-00504227
D. L. Donoho, De-noising by soft-thresholding, IEEE Transactions on Information Theory, vol.41, issue.3, pp.613-627, 1995.
A. Cohen, I. Daubechies, and J. Feauveau, Biorthogonal bases of compactly supported wavelets, Communications on Pure and Applied Mathematics, vol.45, issue.5, pp.485-560, 1992.
R. A. Wannamaker, S. P. Lipshitz, J. Vanderkooy, and J. N. Wright, A theory of nonsubtractive dither, IEEE Transactions on Signal Processing, vol.48, issue.2, pp.499-516, 2000.
J. Vanderkooy and S. P. Lipshitz, Dither in digital audio, Journal of the Audio Engineering Society, vol.35, issue.12, pp.966-975, 1987.
B. Usevitch, Optimal bit allocation for biorthogonal wavelet coding, Data Compression Conference, pp.387-395, 1996.
DOI : 10.1109/dcc.1996.488344
C. E. Shannon, A mathematical theory of communication, Bell system technical journal, vol.27, 1948.
H. W. Kuhn and A. W. Tucker, Nonlinear programming, Berkeley Symposium on Mathematical Statistics and Probability, pp.481-492, 1951.
M. Carlavan, L. Blanc-féraud, M. Antonini, C. Thiebaut, C. Latry et al., An optimized structure for joint noisy image coding/denoising, 2012.
H. Gish and J. Pierce, Asymptotically efficient quantizing, IEEE Transactions on Information Theory, vol.14, issue.5, pp.676-683, 1968.
DOI : 10.1109/tit.1968.1054193
