Sensitivity Analysis of a Large Scale Integrated Land Use and Transportation System - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this work we perform sensitivity analysis of an integrated land use and transportation model. The modeling system used is TRANUS and the region modeled is the Grenoble urban agglomeration. The total eff ect of the input land use parameters on the Quantities Of Interest (QoI) is investigated, which is the mean squared error in land use assignments. It is observed that 3 amongst 100 uncertain input parameters have maximum contribution towards QoI uncertainty.
CompSust2012.pdf (92.36 Ko) Télécharger le fichier
hal-00748575 , version 1 (05-11-2012)
  • HAL Id : hal-00748575 , version 1
Parikshit Dutta, Élise Arnaud, Emmanuel Prados, Mathieu Saujot, Benoit Lefevre. Sensitivity Analysis of a Large Scale Integrated Land Use and Transportation System. CompSust'12 - 3rd International Conference on Computational Sustainability, Jul 2012, Copenhagen, Denmark. ⟨hal-00748575⟩
257 Consultations
145 Téléchargements
