New interface
Reports (Contract/project report)
The Generalized Object Encoding (GOE) LDPC-Staircase FEC Scheme
Vincent Roca 1, * Aline Roumy 2 Bessem Sayadi 3
* Corresponding author
1 PLANETE - Protocols and applications for the Internet
Inria Grenoble - Rhône-Alpes, CRISAM - Inria Sophia Antipolis - Méditerranée
2 TEMICS - Digital image processing, modeling and communication
IRISA - Institut de Recherche en Informatique et Systèmes Aléatoires, Inria Rennes – Bretagne Atlantique
Abstract : This document describes a Generalized Object Encoding (GOE) FEC Scheme for the protection of one or multiple objects, in the context of a Content Delivery Protocol (CDP) like FLUTE/ALC, FCAST/ALC or FCAST/NORM. Unlike [RFC5052], the GOE approach [GOE] decouples the definition of Generalized Objects over which FEC encoding takes place homogeneously, from the natural source object boundaries. This separation enables either an Unequal Erasure Protection (UEP) of different portions of a given source object, or an efficient and global protection of a set of potentially small files, depending on the way the Generalized Objects are defined. The present document defines the GOE LDPC-Staircase FEC Scheme, i.e., the GOE version of the FEC Encoding ID 3 (LDPC-Staircase) defined in [RFC5170] with the further restriction that the number of encoding symbols per group (i.e., the number of symbols sent in the same packet) MUST be equal to 1 (G=1). This document does not change the LDPC-Staircase code definition, and therefore it inherits most of [RFC5170]. It only modifies the FEC Payload ID and FEC OTI, i.e., it addresses the problem of UEP and efficient file bundle protection by means of pure signaling approach.
Document type :
Complete list of metadata
https://hal.inria.fr/hal-00748856
Contributor : Ist Rennes Connect in order to contact the contributor
Submitted on : Tuesday, November 6, 2012 - 10:53:06 AM
Last modification on : Thursday, October 27, 2022 - 3:44:48 AM
Identifiers
  • HAL Id : hal-00748856, version 1
Citation
Vincent Roca, Aline Roumy, Bessem Sayadi. The Generalized Object Encoding (GOE) LDPC-Staircase FEC Scheme. [Contract] 2011, pp.15. ⟨hal-00748856⟩
Share
Metrics
Record views
126
