On the design of Adaptive Mesh Refinement applications based on software components - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Designing Adaptive Mesh Refinement based applications is a very complex task. The aim of this paper is to study whether component models could simplify their conception and which concepts are needed. The analysis is based on an implementation of an AMR method on top of two component models, ULCM and SALOME.
Fichier non déposé
hal-00749432 , version 1 (07-11-2012)
Vincent Pichon, Christian Pérez, André Ribes. On the design of Adaptive Mesh Refinement applications based on software components. Workshop on Component-Based High Performance Computing (2010), Oct 2010, Bruxelles, Belgium. pp.383-386, ⟨10.1109/GRID.2010.5698012⟩. ⟨hal-00749432⟩
82 Consultations
0 Téléchargements
