Acoustic control by wave field synthesis, The Journal of the Acoustical Society of America, vol.93, issue.5, pp.2764-2778, 1993. ,
DOI : 10.1121/1.405852
Multiactuator panels for wave field synthesis: Evolution and present developments, Journal for Audio Engineering Society, vol.58, issue.12, pp.1045-1063, 2010. ,
Database of Multichannel In-Ear and Behind-the-Ear Head-Related and Binaural Room Impulse Responses, EURASIP Journal on Advances in Signal Processing, vol.36, issue.3, p.298605, 2009. ,
DOI : 10.1016/j.sigpro.2005.07.038
Compressed sensing Information Theory, IEEE Transactions on, vol.52, issue.4, pp.1289-1306, 2006. ,
Blind channel identification for speech dereverberation using ?1-norm sparse learning, Advances in Neural Information Processing Systems, pp.921-928, 2007. ,
Double Sparsity: Towards Blind Estimation of Multiple Channels, Proc. Int. Conf. on Latent Variable Analysis and Signal Separation, pp.571-578, 2010. ,
DOI : 10.1007/978-3-642-15995-4_71
URL : https://hal.archives-ouvertes.fr/inria-00537756
Compressed sensing for acoustic response reconstruction: Interpolation of the early part, 2011 IEEE Workshop on Applications of Signal Processing to Audio and Acoustics (WASPAA), pp.225-228, 2011. ,
DOI : 10.1109/ASPAA.2011.6082298
URL : https://hal.archives-ouvertes.fr/hal-00766979
A compressed sensing approach to the simultaneous recording of multiple room impulse responses, 2011 IEEE Workshop on Applications of Signal Processing to Audio and Acoustics (WASPAA), pp.285-288, 2011. ,
DOI : 10.1109/ASPAA.2011.6082284
URL : https://hal.archives-ouvertes.fr/hal-00612911
On the use of the integrated impulse response method for laboratory reverberation measurements, Journal of Sound and Vibration, vol.56, issue.3, pp.341-362, 1978. ,
DOI : 10.1016/S0022-460X(78)80152-7
On estimating room impulse responses from recorded balloon pops, 129th Audio Engineering Society Convention, 2010. ,
Integrated???impulse method measuring sound decay without using impulses, The Journal of the Acoustical Society of America, vol.66, issue.2, pp.497-500, 1979. ,
DOI : 10.1121/1.383103
Impulse-response and reverberation-decay measurements made by using a periodic pseudorandom sequence, Applied Acoustics, vol.29, issue.3, pp.193-205, 1990. ,
DOI : 10.1016/0003-682X(90)90018-P
Simultaneous measurement of multichannel acoustic systems, Journal of the Audio Engineering Society, vol.52, issue.12, pp.26-42, 2004. ,
Comments on aspects of MLS measuring systems, Journal of the Audio Engineering Society, vol.43, issue.1, pp.48-49, 1995. ,
Simultaneous measurement of impulse response and distortion with a swept-sine technique, Proc. AES 108th Convention, pp.18-22, 2000. ,
Comparison of different impulse response measurement techniques, Journal of the Audio Engineering Society, vol.50, issue.4, pp.249-262, 2002. ,
Nonlinear system identification using exponential swept-sine signal Instrumentation and Measurement, IEEE Transactions on, vol.59, issue.8, pp.2220-2229, 2010. ,
Multiple exponential sweep method for fast measurement of head-related transfer functions, Journal of the Audio Engineering Society, vol.55, issue.78, pp.623-637, 2007. ,
Beyond the Narrowband Approximation: Wideband Convex Methods for Under-Determined Reverberant Audio Source Separation, IEEE Transactions on Audio, Speech, and Language Processing, vol.18, issue.7, pp.1818-1829, 2010. ,
DOI : 10.1109/TASL.2010.2050089
URL : https://hal.archives-ouvertes.fr/hal-00435897
A Wavelet Tour of Signal Processing, 1999. ,
For most large underdetermined systems of linear equations the minimal ???1-norm solution is also the sparsest solution, Communications on Pure and Applied Mathematics, vol.50, issue.6, pp.797-829, 2006. ,
DOI : 10.1002/cpa.20132
MAP-based underdetermined blind source separation of convolutive mixtures by hierarchical clustering and l1-norm minimization, EURASIP Journal on Applied Signal Processing, vol.2007, issue.1, pp.81-81, 2007. ,
Should Penalized Least Squares Regression be Interpreted as Maximum A Posteriori Estimation?, IEEE Transactions on Signal Processing, vol.59, issue.5, 2010. ,
DOI : 10.1109/TSP.2011.2107908
URL : https://hal.archives-ouvertes.fr/inria-00486840
A Fast Iterative Shrinkage-Thresholding Algorithm for Linear Inverse Problems, SIAM Journal on Imaging Sciences, vol.2, issue.1, pp.183-202, 2009. ,
DOI : 10.1137/080716542
Fonctions convexes duales et points proximaux dans un espace hilbertien, CR Acad. Sci. Paris Sér. A Math, vol.255, pp.2897-2899, 1962. ,
Signal Recovery by Proximal Forward-Backward Splitting, Multiscale Modeling & Simulation, vol.4, issue.4, pp.1168-1200, 2006. ,
DOI : 10.1137/050626090
URL : https://hal.archives-ouvertes.fr/hal-00017649
The Signal Separation Evaluation Campaign Achievements and remaining challenges, Signal Processing, vol.92, 1928. ,
URL : https://hal.archives-ouvertes.fr/inria-00579398
New Method of Measuring Reverberation Time, The Journal of the Acoustical Society of America, vol.37, issue.3, pp.409-412, 1965. ,
DOI : 10.1121/1.1909343
-penalized functionals, Inverse Problems, vol.25, issue.3, pp.35-43, 2009. ,
DOI : 10.1088/0266-5611/25/3/035008
URL : https://hal.archives-ouvertes.fr/hal-00309817
