Recent advances in signal processing, pp.211-236, 2010. ,
Comparison of two approaches for differentiating full-field data in solid mechanics, Measurement Science and Technology, vol.21, issue.1, pp.15703-15713, 2007. ,
DOI : 10.1088/0957-0233/21/1/015703
URL : https://hal.archives-ouvertes.fr/emse-00509118
Estimation of the strain field from full-field displacement noisy data, European Journal of Computational Mechanics, vol.17, pp.5-7857, 2008. ,
URL : https://hal.archives-ouvertes.fr/emse-00497681
Demodulation of spatial carrier images: performance analysis of several algorithms, Experimental Mechanics, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00834981
Investigation of the grid method for accurate in-plane strain measurement, Measurement Science and Technology, vol.20, issue.9, p.20095102, 2009. ,
DOI : 10.1088/0957-0233/20/9/095102
A Procedure for Accurate One-Dimensional Strain Measurement Using the Grid Method, Experimental Mechanics, vol.29, issue.7???8, pp.841-854, 2009. ,
DOI : 10.1007/s11340-008-9203-8
Strain Measurement by Digital Image Correlation: Influence of Two Types of Speckle Patterns Made from Rigid or Deformable Marks, Strain, vol.36, issue.5, pp.357-365, 2012. ,
DOI : 10.1111/j.1475-1305.2011.00831.x
Assessment of Digital Image Correlation Measurement Errors: Methodology and Results, Experimental Mechanics, vol.43, issue.4, pp.49353-370, 2009. ,
DOI : 10.1007/s11340-008-9204-7
URL : https://hal.archives-ouvertes.fr/hal-00881043
On optimal kernel choice for deconvolution, Statistics & Probability Letters, vol.76, issue.15, pp.1594-1602, 2006. ,
DOI : 10.1016/j.spl.2006.04.016
Investigation of martensitic microstructures in a monocrystalline Cu???Al???Be shape memory alloy with the grid method and infrared thermography, Mechanics of Materials, vol.45, pp.34-51, 2012. ,
DOI : 10.1016/j.mechmat.2011.09.007
Restoration of blurred images for surface roughness evaluation using machine vision, Tribology International, vol.43, issue.1-2, pp.268-276, 2010. ,
DOI : 10.1016/j.triboint.2009.05.030
General least-squares smoothing and differentiation by the convolution (Savitzky-Golay) method, Analytical Chemistry, vol.62, issue.6, pp.570-573, 1990. ,
DOI : 10.1021/ac00205a007
Studying the Mechanical Behaviour of Asphalt Mixture with the Grid Method, Strain, vol.28, issue.1, 2012. ,
DOI : 10.1111/str.12006
Use of rigid-body motion for the investigation and estimation of the measurement errors related to digital image correlation technique, Optics and Lasers in Engineering, vol.46, issue.2, pp.185-196, 2008. ,
DOI : 10.1016/j.optlaseng.2007.05.008
Assessment of measuring errors in DIC using deformation fields generated by plastic FEA, Optics and Lasers in Engineering, vol.47, issue.7-8, pp.747-753, 2009. ,
DOI : 10.1016/j.optlaseng.2009.03.007
Quality assessment of speckle patterns for digital image correlation, Optics and Lasers in Engineering, vol.44, issue.11, pp.1132-1145, 2006. ,
DOI : 10.1016/j.optlaseng.2005.10.004
An iterative technique for the rectification of observed distributions, The Astronomical Journal, vol.79, issue.6, pp.745-754, 1974. ,
DOI : 10.1086/111605
Two-dimensional deconvolution applied to phasestepped shearography, Optics and Lasers in Engineering, vol.26, pp.1594-1602, 2006. ,
DOI : 10.1016/0143-8166(95)00138-7
Application of iteration and finite element smoothing technique for displacement and strain measurement of digital speckle correlation, Optics and Lasers in Engineering, vol.45, issue.1, pp.57-63, 2007. ,
DOI : 10.1016/j.optlaseng.2006.04.012
Mean intensity gradient: An effective global parameter for quality assessment of the speckle patterns used in digital image correlation, Optics and Lasers in Engineering, vol.48, issue.4, pp.469-477, 2010. ,
DOI : 10.1016/j.optlaseng.2009.08.010
Calibration and evaluation of optical systems for full-field strain measurement, Optics and Lasers in Engineering, vol.45, issue.5, pp.45550-564, 2007. ,
DOI : 10.1016/j.optlaseng.2006.08.012
Bayesian-Based Iterative Method of Image Restoration*, Journal of the Optical Society of America, vol.62, issue.1, pp.55-59, 1972. ,
DOI : 10.1364/JOSA.62.000055
Deconvolution in astronomy: A review. Publications of the Astronomical Society of the Pacific, pp.1051-1069, 2002. ,
Towards deconvolution to enhance the grid method for in-plane strain measurement, Inverse Problems and Imaging, vol.8, issue.1, 2012. ,
DOI : 10.3934/ipi.2014.8.259
URL : https://hal.archives-ouvertes.fr/hal-00749804
Photomechanics, Topics in Applied Physic 77, chapter Fringe Analysis, pp.55-102, 2000. ,
Solutions of ill-posed problems, 1977. ,
Quantitative Error Assessment in Pattern Matching: Effects of Intensity Pattern Noise, Interpolation, Strain and Image Contrast on Motion Measurements, Strain, vol.47, issue.2, pp.160-178, 2009. ,
DOI : 10.1111/j.1475-1305.2008.00592.x
Extrapolation, Interpolation, and Smoothing of Stationary Time Series, 1964. ,
