The "Back and Forth Nudging" algorithm for oceanographic data assimilation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
In this paper, we generalize the so-called "nudging" algorithm in order to identify the initial condition of a dynamical system from experimental observations.
Auroux_Blum.pdf (273.12 Ko) Télécharger le fichier
hal-00750243 , version 1 (09-11-2012)
  • HAL Id : hal-00750243 , version 1
Didier Auroux, Jacques Blum. The "Back and Forth Nudging" algorithm for oceanographic data assimilation. 5th WMO Symposium on data assimilation, 2009, Melbourne, Australia. ⟨hal-00750243⟩
258 Consultations
162 Téléchargements
