New interface
Journal articles
A review on local asymptotic stability analysis for mathematical models of hematopoiesis with delay and delay-dependent coefficients
Fabien Crauste 1, 2, *
* Corresponding author
1 DRACULA - Multi-scale modelling of cell dynamics : application to hematopoiesis
CGPhiMC - Centre de génétique et de physiologie moléculaire et cellulaire, Inria Grenoble - Rhône-Alpes, ICJ - Institut Camille Jordan [Villeurbanne]
Abstract : Stability analysis of mathematical models of hematopoiesis (blood cell production process), described by differential equations with delay, needs to locate eigenvalues of characteristic equations that are usually exponential polynomial functions with delay-dependent coefficients. It is then more complicated than for ordinary differential equations to determine conditions for all roots to have negative real parts. We present, on three models of increasing complexity, the tools and method that can be used, with their advantages and their limitations. The method consists in the reduction of the problem to the localization of roots of a real function, these roots giving critical values of the delay for which stability possibly switches.
Complete list of metadata
Cited literature [25 references]  Display  Hide  Download
https://hal.inria.fr/hal-00750271
Contributor : Fabien Crauste Connect in order to contact the contributor
Submitted on : Friday, November 9, 2012 - 1:25:36 PM
Last modification on : Tuesday, October 25, 2022 - 4:17:59 PM
Long-term archiving on: : Sunday, February 10, 2013 - 3:41:45 AM
File
ATPS-2011-Crauste-Fabien.pdf
Identifiers
  • HAL Id : hal-00750271, version 1
Citation
Fabien Crauste. A review on local asymptotic stability analysis for mathematical models of hematopoiesis with delay and delay-dependent coefficients. Annals of the Tiberiu Popoviciu Seminar of functional equations, approximation and convexity, 2011, 9, pp.121-143. ⟨hal-00750271⟩
Share
Metrics
Record views
320
Files downloads
468
