Journal articles
Asymptotic Behavior of a Discrete Maturity Structured System of Hematopoietic Stem Cells Dynamics with Several Delays
Mostafa Adimy 1 Fabien Crauste 1, 2, * Abderrahim El Abdllaoui 3
* Corresponding author
1 DRACULA - Multi-scale modelling of cell dynamics : application to hematopoiesis
CGPhiMC - Centre de génétique et de physiologie moléculaire et cellulaire, Inria Grenoble - Rhône-Alpes, ICJ - Institut Camille Jordan [Villeurbanne]
Abstract : We propose and analyze a mathematical model of hematopoietic stem cell dynamics. This model takes into account a finite number of stages in blood production, characterized by cell maturity levels, which enhance the difference, in the hematopoiesis process, between dividing cells that differentiate (by going to the next stage) and dividing cells that keep the same maturity level (by staying in the same stage). It is described by a system of n nonlinear differential equations with n delays. We study some fundamental properties of the solutions, such as boundedness and positivity, and we investigate the existence of steady states. We determine some conditions for the local asymptotic stability of the trivial steady state, and obtain a sufficient condition for its global asymptotic stability by using a Lyapunov functional. Then we prove the instability of axial steady states. We study the asymptotic behavior of the unique positive steady state and obtain the existence of a stability area depending on all the time delays. We give a numerical illustration of this result for a system of four equations.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/hal-00750285
Contributor : Fabien Crauste Connect in order to contact the contributor
Submitted on : Friday, November 9, 2012 - 1:48:32 PM
Last modification on : Monday, May 16, 2022 - 3:12:01 PM
Links full text
Identifiers
Citation
Mostafa Adimy, Fabien Crauste, Abderrahim El Abdllaoui. Asymptotic Behavior of a Discrete Maturity Structured System of Hematopoietic Stem Cells Dynamics with Several Delays. Mathematical Modelling of Natural Phenomena, EDP Sciences, 2006, 1 (2), pp.1-22. ⟨10.1051/mmnp:2008001⟩. ⟨hal-00750285⟩
Share
Metrics
Record views
187
