CLOP: Confident Local Optimization for Noisy Black-Box Parameter Tuning - Archive ouverte HAL Access content directly
Conference Papers Year : 2012
Rémi Coulom
  • Function : Author
  • PersonId : 836867
Artificial intelligence in games often leads to the problem of parameter tuning. Some heuristics may have coefficients, and they should be tuned to maximize the win rate of the program. A possible approach is to build local quadratic models of the win rate as a function of program parameters. Many local regression algorithms have already been proposed for this task, but they are usually not robust enough to deal automatically and efficiently with very noisy outputs and non-negative Hessians. The CLOP principle, which stands for Confident Local OPtimization, is a new approach to local regression that overcomes all these problems in a simple and efficient way. CLOP discards samples whose estimated value is confidently inferior to the mean of all samples. Experiments demonstrate that, when the function to be optimized is smooth, this method outperforms all other tested algorithms.
Not file
Dates and versions
hal-00750326 , version 1 (09-11-2012)
Identifiers
Cite
Rémi Coulom. CLOP: Confident Local Optimization for Noisy Black-Box Parameter Tuning. Advances in Computer Games - 13th International Conference, Nov 2011, Tilburg, Netherlands. pp.146-157, ⟨10.1007/978-3-642-31866-5_13⟩. ⟨hal-00750326⟩
107 View
0 Download
Share
