New interface
Conference papers
Fiedler Random Fields: A Large-Scale Spectral Approach to Statistical Network Modeling
Abstract : Statistical models for networks have been typically committed to strong prior assumptions concerning the form of the modeled distributions. Moreover, the vast majority of currently available models are explicitly designed for capturing some specific graph properties (such as power-law degree distributions), which makes them unsuitable for application to domains where the behavior of the target quantities is not known a priori. The key contribution of this paper is twofold. First, we introduce the Fiedler delta statistic, based on the Laplacian spectrum of graphs, which allows to dispense with any parametric assumption concerning the modeled network properties. Second, we use the defined statistic to develop the Fiedler random field model, which allows for efficient estimation of edge distributions over large-scale random networks. After analyzing the dependence structure involved in Fiedler random fields, we estimate them over several real-world networks, showing that they achieve a much higher modeling accuracy than other well-known statistical approaches.
Complete list of metadata
Cited literature [20 references]  Display  Hide  Download
https://hal.inria.fr/hal-00750345
Contributor : Antonino Freno Connect in order to contact the contributor
Submitted on : Thursday, November 22, 2012 - 3:15:14 PM
Last modification on : Friday, February 4, 2022 - 3:19:23 AM
Long-term archiving on: : Saturday, February 23, 2013 - 2:40:10 AM
File
extended_paper.pdf
Identifiers
  • HAL Id : hal-00750345, version 1
Collections
Citation
Antonino Freno, Mikaela Keller, Marc Tommasi. Fiedler Random Fields: A Large-Scale Spectral Approach to Statistical Network Modeling. Neural Information Processing Systems (NIPS), Dec 2012, Lake Tahoe, United States. ⟨hal-00750345⟩
Share
Metrics
Record views
212
Files downloads
115
