The volume algorithm: producing primal solutions with a subgradient method, Mathematical Programming, vol.87, issue.3, pp.385-399, 2000. ,
DOI : 10.1007/s101070050002
Acceleration of cutting-plane and column generation algorithms: Applications to network design, Networks, vol.3, issue.5, pp.3-17, 2007. ,
DOI : 10.1002/net.20137
Comparison of bundle and classical column generation, Mathematical Programming, vol.94, issue.1, pp.299-344, 2008. ,
DOI : 10.1007/s10107-006-0079-z
URL : https://hal.archives-ouvertes.fr/inria-00342510
Stabilized column generation, Discrete Mathematics, vol.194, issue.1-3, pp.229-237, 1999. ,
DOI : 10.1016/S0012-365X(98)00213-1
An In-Out Approach to Disjunctive Optimization, Lect. N. in Comp. Sc, vol.6140, pp.136-140, 2010. ,
DOI : 10.1007/978-3-642-13520-0_17
Convex Nondifferentiable Optimization: A Survey Focused on the Analytic Center Cutting Plane Method. Optimization Methods and Software, pp.805-867, 2002. ,
Chebyshev center based column generation, Discrete Applied Mathematics, vol.159, issue.18, 2011. ,
DOI : 10.1016/j.dam.2011.08.009
URL : http://doi.org/10.1016/j.dam.2011.08.009
Nonsmooth Dual Methods in Integer Programming, 1999. ,
Exact algorithm over an arc-time-indexed formulation for parallel machine scheduling problems, Mathematical Programming Computation, vol.4, issue.2, pp.259-290, 2010. ,
DOI : 10.1007/s12532-010-0019-z
A generic view of Dantzig???Wolfe decomposition in mixed integer programming, Operations Research Letters, vol.34, issue.3, pp.296-306, 2006. ,
DOI : 10.1016/j.orl.2005.05.009
URL : https://hal.archives-ouvertes.fr/inria-00342623
Implementing Mixed Integer Column Generation, In Column Generation, Kluwer, 2005. ,
DOI : 10.1007/0-387-25486-2_12
URL : https://hal.archives-ouvertes.fr/inria-00342630
Weighted Dantzig-Wolfe Decomposition for Linear Mixed-Integer Programming, Int. Trans. O. R, vol.4, pp.151-162, 1997. ,
DOI : 10.1016/s0969-6016(97)00001-4
