Abstract : In this paper we propose a new way to achieve a navigation task (visual path following) for a non-holonomic vehicle. We consider an image-based navigation process. We show that it is possible to navigate along a visual path without relying on the extraction, matching and tracking of geometric visual features such as keypoint. The new proposed approach relies directly on the information (entropy) contained in the image signal. We show that it is possible to build a control law directly from the maximisation of the shared information between the current image and the next key image in the visual path. The shared information between those two images is obtained using mutual information that is known to be robust to illumination variations and occlusions. Moreover the generally complex task of features extraction and matching is avoided. Both simulations and experiments on a real vehicle are presented and show the possibilities and advantages offered by the proposed method.
https://hal.inria.fr/hal-00750615 Contributor : Eric MarchandConnect in order to contact the contributor Submitted on : Friday, December 7, 2012 - 10:59:17 PM Last modification on : Thursday, January 20, 2022 - 4:20:07 PM Long-term archiving on: : Saturday, December 17, 2016 - 11:02:11 PM
Amaury Dame, Eric Marchand. Using mutual information for appearance-based visual path following. Robotics and Autonomous Systems, Elsevier, 2013, 61 (3), pp.259-270. ⟨10.1016/j.robot.2012.11.004⟩. ⟨hal-00750615v2⟩
