Visual navigation of a mobile robot with laser-based collision avoidance - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue The International Journal of Robotics Research Année : 2013
In this paper, we propose and validate a framework for visual navigation with collision avoidance for a wheeled mobile robot. Visual navigation consists of following a path, represented as an ordered set of key images, which have been acquired by an on-board camera in a teaching phase. While following such path, the robot is able to avoid obstacles which were not present during teaching, and which are sensed by an on-board range scanner. Our control scheme guarantees that obstacle avoidance and navigation are achieved simultaneously. In fact, in the presence of obstacles, the camera pan angle is actuated to maintain scene visibility while the robot circumnavigates the obstacle. The risk of collision and the eventual avoiding behaviour are determined using a tentacle-based approach. The framework can also deal with unavoidable obstacles, which make the robot decelerate and eventually stop. Simulated and real experiments show that with our method, the vehicle can navigate along a visual path while avoiding collisions.
2012_cherubini_IJRR_HAL.pdf (8.51 Mo) Télécharger le fichier
hal-00750623 , version 1 (11-11-2012)
Andrea Cherubini, François Chaumette. Visual navigation of a mobile robot with laser-based collision avoidance. The International Journal of Robotics Research, 2013, 32, pp.189-205. ⟨10.1177/0278364912460413⟩. ⟨hal-00750623⟩
626 Consultations
847 Téléchargements
