Asymptotic behavior of splitting schemes involving time-subcycling techniques - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2012
In order to integrate numerically a well-posed multiscale evolutionary problem such as a Cauchy problem for an ODE system or a PDE system, using time-subcycling techniques con- sists in splitting the vector field in a fast part and a slow part and take advantage of this decomposition, for example by integrating the fast equation on a much smaller time step than the slow equation (instead of having to integrate the whole system with a very small time step to ensure stability for example). These techniques are designed to improve the computational efficiency and have been been very widely used for schemes, that may have (at least) one com- ponent that has to be computed through an explicit scheme thus constrained by a limitation of the time step (CFL). In this paper, we study the long time behavior of such schemes, that are primarily designed to be convergent in short-time to the solution of the original problem. We develop our analysis on ODE toy-models and illustrate our results numerically on more complex PDE systems.
dujardin_lafitte_bit.pdf (359.16 Ko) Télécharger le fichier
Format : Figure, Image
hal-00751217 , version 1 (13-11-2012)
hal-00751217 , version 2 (04-10-2013)
hal-00751217 , version 3 (10-10-2014)
hal-00751217 , version 4 (05-10-2015)
hal-00751217 , version 5 (06-10-2015)
Guillaume Dujardin, Pauline Lafitte. Asymptotic behavior of splitting schemes involving time-subcycling techniques. 2012. ⟨hal-00751217v3⟩
419 Consultations
336 Téléchargements
