Multinerves and Helly Numbers of Acyclic Families - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The nerve of a family of sets is a simplicial complex that records the intersection pattern of its subfamilies. Nerves are widely used in computational geometry and topology, because the nerve theorem guarantees that the nerve of a family of geometric objects has the same topology as the union of the objects, if they form a good cover. In this paper, we relax the good cover assumption to the case where each subfamily intersects in a disjoint union of possibly several homology cells, and we prove a generalization of the nerve theorem in this framework, using spectral sequences from algebraic topology. We then deduce a new topological Helly-type theorem that unifies previous results of Amenta, Kalai and Meshulam, and Matousek. This Helly-type theorem is used to (re)prove, in a unified way, bounds on transversal Helly numbers in geometric transversal theory.
multinerve-socg.pdf (290.19 Ko) Télécharger le fichier
hal-00752073 , version 1 (12-12-2012)
Éric Colin de Verdière, Grégory Ginot, Xavier Goaoc. Multinerves and Helly Numbers of Acyclic Families. Symposium on Computational Geometry - SoCG '12, Jun 2012, Chapel Hill, United States. pp.209-218, ⟨10.1145/2261250.2261282⟩. ⟨hal-00752073⟩
207 Consultations
276 Téléchargements
