New interface
Reports (Technical report)
The Need for Extended Forward Erasure Correction (FEC) schemes: Problem Position
Vincent Roca 1, * Aline Roumy 2 Bessem Sayadi 3
* Corresponding author
1 PLANETE - Protocols and applications for the Internet
Inria Grenoble - Rhône-Alpes, CRISAM - Inria Sophia Antipolis - Méditerranée
2 Sirocco - Analysis representation, compression and communication of visual data
Inria Rennes – Bretagne Atlantique , IRISA-D5 - SIGNAUX ET IMAGES NUMÉRIQUES, ROBOTIQUE
Abstract : This document discusses the limits of [RFC5052]-compliant traditional FEC schemes, and in particular for two use-cases that are not efficiently addressed, namely Unequal Erasure Protection (UEP) of subsets of an object and file bundle protection. This document defines the problem but not the potential solutions. This is left to companion documents.
Complete list of metadata
https://hal.inria.fr/hal-00752510
Contributor : Aline Roumy Connect in order to contact the contributor
Submitted on : Friday, November 16, 2012 - 5:52:19 AM
Last modification on : Thursday, October 27, 2022 - 3:45:14 AM
Identifiers
  • HAL Id : hal-00752510, version 1
Citation
Vincent Roca, Aline Roumy, Bessem Sayadi. The Need for Extended Forward Erasure Correction (FEC) schemes: Problem Position. [Technical Report] 2012. ⟨hal-00752510⟩
Share
Metrics
Record views
261
