New interface
Preprints, Working Papers, ...
Simultaneous Consensus is Harder than Set Agreement in Message Passing
Abstract : In the traditional consensus task, processes are required to agree on a common value chosen among the initial values of the participants. It is well known that consensus cannot be solved in crashed-prone, asynchronous distributed systems. Two generalizations of the consensus problem have been introduced: k-set agreement and k-simultaneous consensus. The k-set agreement task has the same requirements as consensus except that processes are allowed to decide up to k distinct values. In the k-simultaneous consensus task, each process participates simultaneously in k instances of consensus and is required to decide in at least one of them; any two processes deciding in the same instance must decide the same value. It is known that both tasks are equivalent in the wait-free shared memory model. Perhaps surprisingly, the paper shows that this is no longer the case in the n-process asynchronous message passing model with at most t process crashes. Specifically, the paper establishes that for parameters t, n, k such that t > (n+k−2)/2 , k-simultaneous consensus is strictly harder than k-set agreement. The proof compares the information on failures necessary to solve each task in the failure detector framework and relies on a result in topological combinatorics, namely, the chromatic number of Kneser graphs. The paper also introduces the new failure detector class V Σk , which is a generalization of the quorum failures detector class Σ suited to k-simultaneous consensus.
Document type :
Complete list of metadata
Cited literature [26 references]  Display  Hide  Download
https://hal.inria.fr/hal-00752610
Contributor : Corentin Travers Connect in order to contact the contributor
Submitted on : Saturday, November 17, 2012 - 12:10:32 AM
Last modification on : Saturday, June 25, 2022 - 10:33:25 AM
Long-term archiving on: : Friday, March 31, 2017 - 4:00:22 PM
File
scsa-main-LONGVERSION.pdf
Identifiers
  • HAL Id : hal-00752610, version 2
Citation
Zohir Bouzid, Corentin Travers. Simultaneous Consensus is Harder than Set Agreement in Message Passing. {date}. ⟨hal-00752610v2⟩
Share
Metrics
Record views
140
Files downloads
433
