Stability analysis of sampled-data systems using Sum of Squares - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Automatic Control Année : 2013
This article proposes a new approach to stability analysis of linear systems with sampled-data inputs or channels. The method, based on a variation of the discrete-time Lyapunov approach, provides stability conditions using functional variables subject to convex constraints. These stability conditions can be solved using the sum of squares methodology with little or no conservatism in both the case of synchronous and asynchronous sampling. Numerical examples are included to show convergence.
SOSSamSys2columns.pdf (157.14 Ko) Télécharger le fichier
hal-00753538 , version 1 (19-11-2012)
Alexandre Seuret, Matthew M. Peet. Stability analysis of sampled-data systems using Sum of Squares. IEEE Transactions on Automatic Control, 2013, 58 (6), pp.1620-1625. ⟨10.1109/TAC.2012.2232378⟩. ⟨hal-00753538⟩
277 Consultations
759 Téléchargements
