Application of the Cauchy method for extrapolating/interpolating narrowband system responses, IEEE Transactions on Microwave Theory and Techniques, vol.45, issue.5, pp.837-845, 1997. ,
DOI : 10.1109/22.575608
On the differential structure of matrix-valued rational inner functions. Operator Theory: Advances and Applications, pp.30-66, 1994. ,
Gradient methods for optimal linear system reduction???, International Journal of Control, vol.117, issue.4, p.18, 1973. ,
DOI : 10.1080/00207177308932554
Interpolation of rational matrix functions, of Operator Theory: Advances and Applications. Birkhäuser, 1990. ,
DOI : 10.1007/978-3-0348-7709-1
Approximants for Linear Systems, IMA Journal of Mathematical Control and Information, vol.3, issue.2-3, pp.89-101, 1986. ,
DOI : 10.1093/imamci/3.2-3.89
Identification and rational L2 approximation A gradient algorithm, Automatica, vol.27, issue.2, pp.413-418, 1991. ,
DOI : 10.1016/0005-1098(91)90092-G
Hardy approximation to L p functions on subsets of the circle with 1 ? p < ?. Constructive Approximation, pp.41-56, 1998. ,
Robust identification from band-limited data, IEEE Transactions on Automatic Control, vol.42, issue.9, pp.1318-1325, 1997. ,
DOI : 10.1109/9.623101
URL : https://hal.archives-ouvertes.fr/inria-00074187
Extremal problems of mixed type in H 2 of the circle, 2009. ,
Critical Points and Error Rank in Best H 2 Matrix Rational Approximation of Fixed McMillan Degree, Constructive Approximation, vol.14, issue.2, pp.273-300, 1998. ,
DOI : 10.1007/s003659900075
URL : https://hal.archives-ouvertes.fr/inria-00073728
H 2 -optimal model reduction of MIMO systems, Applied Mathematics Letters, vol.21, 2008. ,
J-contractive matrix functions, reproducing kernel spaces and interpolation, volume 71 of CBMS lecture notes, 1989. ,
A homeomorphism between observable pairs and conditioned invariant subspaces, Systems & Control Letters, vol.30, issue.5, pp.217-223, 1997. ,
DOI : 10.1016/S0167-6911(97)00013-3
Approximation: A Gradient Algorithm Based on Schur Analysis, SIAM Journal on Control and Optimization, vol.36, issue.6, pp.2103-2127, 1998. ,
DOI : 10.1137/S0363012995284230
URL : https://hal.archives-ouvertes.fr/inria-00074158
-error bounds???, International Journal of Control, vol.127, issue.6, pp.1115-1193, 1984. ,
DOI : 10.1109/TIT.1961.1057636
URL : https://hal.archives-ouvertes.fr/in2p3-00956389
$\mathcal{H}_2$ Model Reduction for Large-Scale Linear Dynamical Systems, SIAM Journal on Matrix Analysis and Applications, vol.30, issue.2, 2008. ,
DOI : 10.1137/060666123
Rational approximation of frequency domain responses by vector fitting, IEEE Transactions on Power Delivery, vol.14, issue.3, pp.1052-1061, 1999. ,
DOI : 10.1109/61.772353
A Robust Approach for System Identification in the Frequency Domain, IEEE Transactions on Power Delivery, vol.19, issue.3, pp.1167-1173, 2004. ,
DOI : 10.1109/TPWRD.2003.822530
Constructive algebra methods for the L2-problem for stable linear systems, Automatica, vol.32, issue.12, p.32, 1996. ,
DOI : 10.1016/S0005-1098(96)80002-1
Balanced realizations of discrete-time stable all-pass systems and the tangential Schur algorithm, Linear Algebra and its Applications, 2006. ,
DOI : 10.1016/j.laa.2006.03.027
URL : https://hal.archives-ouvertes.fr/inria-00546784
The optimal projection equations for model reduction and the relationships among the methods of Wilson, Skelton, and Moore, IEEE Transactions on Automatic Control, vol.30, issue.12, p.29, 1985. ,
DOI : 10.1109/TAC.1985.1103865
Frequency domain system identificaton toolbox for matlab, Gamax Ltd, 2004. ,
Optimal hankel-norm model reductions: Multivariable systems, IEEE trans. on Automatic control, issue.4, pp.26832-852, 1981. ,
DOI : 10.1109/cdc.1980.271776
Filter Model Generation from Scattering Parameters using the Cauchy Method, 32nd European Microwave Conference, 2002, 2002. ,
DOI : 10.1109/EUMA.2002.339310
State-space approach to factorization of lossless transfer functions and structured matrices, Linear Algebra and its Applications, vol.162, issue.164, pp.162-164273, 1992. ,
DOI : 10.1016/0024-3795(92)90380-S
RARL2: a Matlab based software for H 2 rational approximation, 2004. ,
Nudelman interpolation, parametrizations of lossless functions and balanced realizations, Automatica, vol.43, issue.8, pp.1329-1338, 2007. ,
DOI : 10.1016/j.automatica.2007.01.020
URL : https://hal.archives-ouvertes.fr/inria-00546743
Matrix rational H/sup 2/ approximation: a state-space approach using Schur parameters, Proceedings of the 41st IEEE Conference on Decision and Control, 2002., 2002. ,
DOI : 10.1109/CDC.2002.1185036
Approximation of linear constant systems, IEEE Transactions on Automatic Control, vol.12, issue.5, pp.585-587, 1967. ,
DOI : 10.1109/TAC.1967.1098680
Principal component analysis in linear systems: Controllability, observability, and model reduction, IEEE Transactions on Automatic Control, vol.26, issue.1, pp.2617-2649, 1981. ,
DOI : 10.1109/TAC.1981.1102568
Parametrizations in control, estimation and filtering problems, 1993. ,
Interpolation, Identification and Sampling, 1997. ,
Sur l'approximation rationnelle des filtres, 1978. ,
DEDALE-HF: a Matlab toolbox dedicated to the equivalent network synthesis for microwave filters ,
PRESTO-HF: a Matlab based toolbox dedicated to the identification problem of low pass coupling parameters of band pass microwave filters, 2004. ,
A new algorithm for L2 optimal model reduction, Automatica, vol.28, issue.5, pp.897-909, 1992. ,
DOI : 10.1016/0005-1098(92)90143-4
Filtering and system identification: a least-square approach, 2007. ,
DOI : 10.1017/CBO9780511618888
Optimal reduction of multivariable systems, International Journal of Control, vol.117, issue.2, pp.267-278, 1979. ,
DOI : 10.1080/00207177908922698
