Reports
Automatic Decidability for Theories Modulo Integer Offsets
Elena Tushkanova 1 Christophe Ringeissen 1 Alain Giorgetti 1 Olga Kouchnarenko 1
1 CASSIS - Combination of approaches to the security of infinite states systems
FEMTO-ST - Franche-Comté Électronique Mécanique, Thermique et Optique - Sciences et Technologies (UMR 6174), Inria Nancy - Grand Est, LORIA - FM - Department of Formal Methods
Abstract : Many verification problems can be reduced to a satisfiability problem modulo theories. For building satisfiability procedures the rewriting-based approach uses a general calculus for equational reasoning named superposition. Schematic superposition, in turn, provides a mean to reason on the derivations computed by superposition. Until now, schematic superposition was only studied for standard superposition. We present a schematic superposition calculus modulo a fragment of arithmetics, namely the theory of Integer Offsets. This new schematic calculus is used to prove the decidability of the satisfiability problem for some theories extending Integer Offsets. We illustrate our theoretical contribution on theories representing extensions of classical data structures, e.g., lists and records. An implementation in the rewriting-based Maude system constitutes a practical contribution. It enables automatic decidability proofs for theories of practical use.
Document type :
Reports
Complete list of metadata
Cited literature [14 references]  Display  Hide  Download
https://hal.inria.fr/hal-00753896
Contributor : Christophe Ringeissen Connect in order to contact the contributor
Submitted on : Monday, November 19, 2012 - 5:56:07 PM
Last modification on : Friday, January 21, 2022 - 3:09:00 AM
Long-term archiving on: : Thursday, February 21, 2013 - 11:41:43 AM
File
8139.pdf
Identifiers
  • HAL Id : hal-00753896, version 1
Citation
Elena Tushkanova, Christophe Ringeissen, Alain Giorgetti, Olga Kouchnarenko. Automatic Decidability for Theories Modulo Integer Offsets. [Research Report] RR-8139, INRIA. 2012, pp.20. ⟨hal-00753896⟩
Share
Metrics
Record views
207
Files downloads
92
