Linear-time Constant-ratio Approximation Algorithm and Tight Bounds for the Contiguity of Cographs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper we consider a graph parameter called contiguity which aims at encoding a graph by a linear ordering of its vertices. We prove that the contiguity of cographs is unbounded but is always dominated by O(log n), where n is the number of vertices of the graph. And we prove that this bound is tight in the sense that there exists a family of cographs on n vertices whose contiguity is Omega(log n). In addition to these results on the worst-case contiguity of cographs, we design a linear-time constant-ratio approximation algorithm for computing the contiguity of an arbitrary cograph, which constitutes our main result. As a by-product of our proofs, we obtain a min-max theorem, which is worth of interest in itself, stating equality between the rank of a tree and the minimum height of its path partitions.
CographContiguity.pdf (427.02 Ko) Télécharger le fichier
hal-00755257 , version 1 (23-11-2012)
Christophe Crespelle, Philippe Gambette. Linear-time Constant-ratio Approximation Algorithm and Tight Bounds for the Contiguity of Cographs. Seventh International Workshop on Algorithms and Computation, Feb 2013, Kharagpur, India. pp.126-136, ⟨10.1007/978-3-642-36065-7_13⟩. ⟨hal-00755257⟩
575 Consultations
302 Téléchargements
