Type-based complexity analysis for fork processes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We introduce a type system for concurrent programs described as a parallel imperative language using while-loops and fork/wait instructions, in which processes do not share a global memory, in order to analyze computational complexity. The type system provides an analysis of the data-flow based both on a data ramification principle related to tiering discipline and on secure typed languages. The main result states that well-typed processes characterize exactly the set of functions computable in polynomial space under termination, confluence and lock-freedom assumptions. More precisely, each process computes in polynomial time so that the evaluation of a process may be performed in polynomial time on a parallel model of computation. Type inference of the presented analysis is decidable in linear time provided that basic operator semantics is known.
fossacs.pdf (383.29 Ko) Télécharger le fichier
hal-00755450 , version 1 (21-11-2012)
hal-00755450 , version 2 (04-10-2013)
Emmanuel Hainry, Jean-Yves Marion, Romain Péchoux. Type-based complexity analysis for fork processes. 16th International Conference on Foundations of Software Science and Computation Structures (FoSSaCS), Mar 2013, Rome, Italy. pp.305-320, ⟨10.1007/978-3-642-37075-5_20⟩. ⟨hal-00755450v2⟩
298 Consultations
214 Téléchargements
